1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: autosave failure S_rpcLib_RPC_CANTSEND
To: "'J. Lewis Muir'" <[email protected]>, Andrew Johnson <[email protected]>
Date: Mon, 11 Nov 2013 17:07:57 +0000
Lewis,
The vxWorks commands:
netStackSysPoolShow
netStackDataPoolShow
will show you the mbufs.
-----Original Message-----
Sent: Monday, November 11, 2013 10:16 AM
To: Mark Rivers; Andrew Johnson
Cc: [email protected]
Subject: Re: autosave failure S_rpcLib_RPC_CANTSEND
On 11/11/13 9:33 AM, Mark Rivers wrote:
> Hi Lewis,
> Which version of Andrew's BSP are you using?  The asd6-debug versions
> fixed a similar problem when vxWorks repeatedly tried to open a
> socket.  This happened with asyn autoConnect ports when the device was
> offline.  Eventually it would lead to mbuf depletion and errors like
> the ones you are seeing would happen.
> Mark
Hi, Mark.
When I first reported this problem, I was using asd6-debug.  Now it's
running the special image Andrew sent me that does not have an NFS v3
client.  I don't actually know what version this is.
Is there a way I can see a report of available mbufs?  I guess I could
try using devIocStats for this?
Andrew, is the image you sent me asd6-debug sans the NFS v3 client?
Lewis
autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Re: autosave failure S_rpcLib_RPC_CANTSEND Andrew Johnson
Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
RE: autosave failure S_rpcLib_RPC_CANTSEND Mark Rivers
Prev: Re: Subscription updates halting? Andrew Johnson
Next: Re: autosave failure S_rpcLib_RPC_CANTSEND Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
