1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Epics installation
To: "'Vikram Bhagat'" <[email protected]>, epics talk <[email protected]>
Date: Fri, 15 Nov 2013 21:43:18 +0000
For building an IOC that uses asyn, autosave, streamDevice, and std I would recommend just downloading the synApps module:
http://www.aps.anl.gov/bcda/synApps/
If you do that then everything is all set up for you, with dependencies between modules, and a top-level Makefile.  I also has instructions on how to install and build it:
http://www.aps.anl.gov/bcda/synApps/synApps_5_7.html
For extensions you only need to the Top file, not the Configure file.  You install that, and then install the individual extensions under extensions/src.  You edit extensions/configure/RELEASE to set the path to EPICS base and some other things.  Then you run make at the top level of extensions.
From: [email protected] [mailto:[email protected]] On Behalf Of Vikram Bhagat
Sent: Friday, November 15, 2013 2:18 PM
To: epics talk
Subject: Epics installation
Hello,
    Presently i am working on system already installed EPICS.  I started and learning with developing computer serial port driver.
Now i want to establish another system.  I tried to install epics extension and modules.  But can't understand how to install extension and modules.
I downloaded extensionsTop_20120904.tar.gz, and extensionsConfigure_20070703.tar.gz  but don't know what to do with this.
I also downloaded asyn4-21.tar.gz, autosave_R5-1.tar.gz ,  camonitor_cvs.tar.gz ,  StreamDevice-2-6.tgz , std_R3-2.tar.gz   etc but don't know how to install it ...
Is it enough to just untar all these modules?
Thank you
Epics installation Vikram Bhagat
Prev: epics with eclipse Vikram Bhagat
Next: RE: Substitutions defaults and tricks Brown, Garth
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Epics installation Vikram Bhagat
Next: epics with eclipse Vikram Bhagat
