1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Why should I care about breakpoint table monotonicity?
Date: Thu, 21 Nov 2013 16:29:03 -0800
Hello all,
I am currently playing with ai and ao records breakpoint tables.
Documentation is rather sparse on how to implement them.
http://www.aps.anl.gov/epics/EpicsDocumentation/AppDevManuals/RecordRef/Recordref-5.html#MARKER-9-12
I found a couple of interesting emails on the tech-talk mailing list.
Including:
http://www.aps.anl.gov/epics/tech-talk/2010/msg02152.php
(Thank you Stephanie!)
and another
http://www.aps.anl.gov/epics/tech-talk/2010/msg01896.php
"This is a bit of a pain, so I just wrote a blueprint to look at adding the table names to menuConvert automatically in future releases. - Andrew"
Has this been implemented in >3.14.11 ?
But my real question is this: why should I care about the monotonicity of the data in the breakpoint table?
Apparently, I have to set a iocsh variable to 1
"var dbBptNotMonotonic 1"
How does this impact monotonic tables?
Why not always set it to 1?
Why do I need to set it?
(I can only imagine that it has to do with RVAL to VAL conversion .... and VAL to RVAL conversion which may return more than one value.)
Emmanuel
RE: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
Prev: Re: CSS EPICS PV connectivity issue Ralph Lange
Next: RE: Why should I care about breakpoint table monotonicity? Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS EPICS PV connectivity issue Juan Manuel Lozano
