1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Convertion for asynFloat64
To: Benoit <[email protected]>
Cc: [email protected]
Date: Fri, 22 Nov 2013 09:37:31 -0600
On 11/22/13 4:10 AM, Benoit wrote:
> Hi Lewis,
> about my previous problem I was wondering if I could do the conversion
> in one step with something similar as below (This does not work)
> record(ao, "$(S):$(D)_$(C):CavVSet")
>   field(DTYP, "asynFloat64")
>   field(OUT,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))cavvolt")
>   field(VAL, "0")
>   field(PREC, "2")
> record(calcout, "$(S):$(D)_$(C):CavMilliVSet")
>   field(OUT, "$(S):$(D)_$(C):CavVSet PP")
>   field(OCAL, "1000 * VAL")
>   field(PINI, "YES")
>   field(PREC, "1")
> Actually I am doing as below, but I need a temporary record to perform
> this conversion, and It would be simpler to use one record less.
> record(ao, "$(S):$(D)_$(C):CavMilliVSet")
>   field(DESC, "CavMilliVSet Temporary Set Record")
>   field(PINI, "YES")
>   field(EGU,  "mV")
>   field(PREC, "1")
> record(calcout, "$(S):$(D)_$(C):CavMilliVCalc")
>   field(CALC, "1000 * A")
>   field(INPA, "$(S):$(D)_$(C):CavMilliVSet.VAL CP MS")
>   field(PINI, "YES")
Hi, Benoit.
I'm not sure what you're asking.  There are two records in both of your
examples, so I don't see how the first one uses one less record than the
second.
Regardless, I think I see the problem with your first example.  You have
your calculation expression in the OCAL field of the calcout record, but
it should instead be in the CALC field.  The OCAL field is an additional
calculation expression that would only be used if you set the DOPT field
to "Use OCAL".  But you don't need that.  You should just use the CALC
field which will put the result of the expression in the VAL field which
will be written to the OUT link.
Lewis
Re: Convertion for asynFloat64 J. Lewis Muir
Convertion for asynFloat64 Benoit
Re: Convertion for asynFloat64 Benoit
Prev: EpicsSharp issues Christopher J. Pendleton
Next: Re: Convertion for asynFloat64 J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Convertion for asynFloat64 Benoit
