Hi Antonio,
you need only one soft IOC (the one at the MicroBox). In your case you
have to run the OpcIocShell to have an interface between OPC and EPICS.
At Linux you only need channel access clients as caget, camonitor or
higher level clients. A standard soft IOC doesn't support the DTYP
"OPC". This is a special feature of the OpcIocShell.
Hope this resolves your problem
Carsten Winkler
Am 25.11.2013 11:46, schrieb Antonio Borondo:
> Hi all,
> I am trying to deploy an EPICS network between a linux PC, a MicroBox with
> OPC Server and a Siemens PLC.
> The MicroBox basically gets the registers from the PLC, stores them into OPC
> Server database and after puts them into EPICS database using OpcIocShell.
> On the linux PC side I have developed the EPICS IOC which loads the same
> data base.
> My problem comes when I start my IOC and I get the next error message for
> each PV of the data base:
> Can't set "<PV NAME>.DTYP" to "opc"
> Error at or before ")" in path "." file "opc.db" line x"
> Any ideas about how to resolve it?
> Thank you very much,
> Antonio Borondo
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- RE: Error database DTYP Antonio Borondo
- Error database DTYP Antonio Borondo
<2013>
2025
2026
<2013>
2025
2026
