1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Anyone using StreamDevice with local serial ports on Windows?
To: "'[email protected]'" <[email protected]>
Date: Tue, 26 Nov 2013 00:31:06 +0000
I found and fixed a problem in drvAsynSerialPortWin32.c.  When pasynUser->timeout was 0 for a read operation, and the number of characters available to read was 0, it was returning asynSuccess.  This is incorrect, it should return asynTimeout.  Dirk also found a problem that when pasynUser->timeout was 0 it was not returning immediately.
With these fixes StreamDevice works correctly with local serial ports on WIN32.
These fixes will be in the next release of asyn, R4-23.
Sent: Sunday, November 24, 2013 12:25 PM
To: [email protected]
Subject: Anyone using StreamDevice with local serial ports on Windows?
Folks,
I am trying to use StreamDevice with a local serial port on win32-x86.  It is not working.  I’d like to know if the problem is specific to my setup.
Has anyone else used StreamDevice with local serial ports on win32-x86 or windows-x64?
Re: Anyone using StreamDevice with local serial ports on Windows? Oleg A. Makarov
Anyone using StreamDevice with local serial ports on Windows? Mark Rivers
Prev: RE: Breakpoint tables: Raw value must be integer?!? Emmanuel Mayssat
Next: Re: EpicsSharp issues Alain Bertrand
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Anyone using StreamDevice with local serial ports on Windows? Mark Rivers
Next: Re: Anyone using StreamDevice with local serial ports on Windows? Oleg A. Makarov
