For the tech-talk record, the problem was resolved.
Sent: Friday, November 29, 2013 6:26 AM
To: Mark Rivers
Subject: Re: All Pvs disconnected
Yes, you are right, they use different mechanism. I had to change it both in CSS and in EPICS variables, now it is working. Thank you
so much for your help one more time.
On the machine that is working type:
printenv | grep EPICS
at the shell and
epicsPrtEnvParams
at the IOC prompt.
On the machine that is not working do the same thing.
And on the machine that is not working at the shell do
caget SOME_PV_NAME
cainfo SOME_PV_NAME
It could be you will be able to access the PVs using the caget and cainfo commands, which use the C CA library, but not from CSS which uses the Java CA library. I think CSS uses a different mechanism to set EPICS_CA_ADDR_LIST, etc.
Sent: Thursday, November 28, 2013 10:31 AM
To: Mark Rivers; techtalkForo
I have changed that variables but still not working.
I have the same configuration of that machine, here, and it works, without internet. And it is not connected, no cable.
Thanks.
Julio.
El Jueves 28 de noviembre de 2013 17:01, Mark Rivers <[email protected]> escribió:
If the Ethernet port is disconnected then CA does not work. I think if you set EPICS_CA_AUTO_ADDR_LIST=NO and EPICS_CA_ADDR_LIST=localhost it will work, but I am not certain.
You could also just plug the Ethernet cable into a cheap switch with nothing else connected to it :-)
From: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>]
on behalf of Julio Calvo [[email protected]<mailto:[email protected]>]
Sent: Thursday, November 28, 2013 9:53 AM
To: techtalkForo
Subject: All Pvs disconnected
Hello,
I have move a computer from my lab, it was working perfectly, it was connected to internet, now, this computer is in other place without internet connection for security reasons. I have open the IOC, pvs are ok after dbl. But CSS GUI appears as disconnected,
any idea?. I have done this several times and I never found this problem. Do I have to configure something?.
Thanks.
Julio.
Re: Increasing scan rate to 10 kHz Benjamin Franksen
areaDetectorR1-9-1: "NDPluginStdArrays.cpp" trying to access private member "asynStdInterfaces" Gabriele Salvato
<2013>
2025
2026
RE: All Pvs disconnected Mark Rivers
<2013>
2025
2026
ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
