1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: iocsh and redirection
To: "John Dobbins" <[email protected]>, "EPICS Tech-Talk" <[email protected]>
Date: Fri, 6 Dec 2013 19:25:54 -0000
Hi John,
I am able to reproduce anomalous behaviour, using SoftIoc, on my Windows PC by:
epics>1>help.txt
epics>help
help.txt is created, but empty.
To the screen, I get:
 ": Invalid argument
Cheers,
Peter.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of John Dobbins
Sent: 06 December 2013 17:24
To: EPICS Tech-Talk
Subject: iocsh and redirection
All,
I was experimenting with redirection in the iocsh and the results were not as I expected.
I have used commands like
dbl>records.txt
in the past and they work fine.
So I created an example IOC (makeBaseApp.pl -t example) and tried:
epics> 1>test.txt
epics> dbl
and got:
Can't open "": No such file or directory.
the file test.txt was created but was empty.
Running the same test on another computer might produce
epics> 1>test.txt
epics> dbl
Can't open "ØîØð8": No such file or directory.
again test.txt is created but empty.
And interestingly on a third computer
epics> 1>test.txt
epics> dbl
will create test.txt but will output a list of records to a file named "èþ8Þ"
BTW, I was playing with this because I wanted to redirect stderr to a
file. The App Developer Guide mentions epicsStdioRedirect and I was
wondering what it would take to get redirection to work in any specific IOC.
Regards and thanks,
John Dobbins
Cornell University
iocsh and redirection John Dobbins
Prev: Re: iocsh and redirection Eric Norum
Next: RE: which time/timestamp format to use for an EPICS facility? Di Maio Franck
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: CSS Boy - control a button with keyboard shortcut Maurizio Montis
