1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: which time/timestamp format to use for an EPICS facility?
To: EPICS Tech Talk <[email protected]>
Cc: Di Maio Franck <[email protected]>
Date: Mon, 9 Dec 2013 15:33:15 +0000
Hi Franck,
it's good to hear that ITER is prefering TAI over UTC as well :-)
> Actually, we are suppressing POSIX UTC from timing boards' drivers
> only & convert to UTC for applications (inc. EPICS records).
What exactly does converting from TAI to UTC for an EPICS record mean? I
see two ways to do that:
1. Convert from TAI to UTC. This requires leap second information on all
EPICS IOCs.
2. Just copy the TAI timestamp into an EPICS timestamp and let the
clients do the conversion. Since TAI has no leap seconds this should
work smoothly. But strictly speaking this is against the definition of
EPICS timestamps (which are defined to be in UTC - see epicsTime.h).
If you chose 1.: Do you periodically download the leap second
information from a central server into all your IOCs? How do you deal
with the fact that EPICS timestamps do not have a representation for
leap seconds?
If you chose 2.: How do you make sure all your clients are converting
time in the right way (including leap seconds)? Do you have any
procedures in place for that?
Thanks a lot,
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
RE: which time/timestamp format to use for an EPICS facility? Di Maio Franck
which time/timestamp format to use for an EPICS facility? Konrad, Martin
Re: which time/timestamp format to use for an EPICS facility? Konrad, Martin
Re: which time/timestamp format to use for an EPICS facility? Benoit
Prev: RE: which time/timestamp format to use for an EPICS facility? Di Maio Franck
Next: RE: which time/timestamp format to use for an EPICS facility? Di Maio Franck
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
