1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ai records: pool (SCAN) VS pull (FLNK) VS push (some examples)
Cc: EPICS mailing list <[email protected]>
Date: Tue, 10 Dec 2013 20:22:38 +0100
Hi Mark,
I did put  field(FLNK,"$(user):AllInterlocksRdbk.PROC PP")
I still have my PV with:  INVALID, UDF_ALARM even after setting correctly the CtrlManualCmd
I don't understand why!
$(user):AllInterlocksRdbk in the database, only "$(user):AllInterlocks.
In my previous mail I got rid off the Rdbk Suffix by doing a bad copy paste.
Do you have a good tutorial to use the FLNK field in various case.
Benoit RAT
www.neub.co.nr
On Tue, Dec 10, 2013 at 7:30 PM, Mark Rivers <[email protected]> wrote:
Is the database you sent incomplete?  You have
            field(FLNK,"$(user):AllInterlocksRdbk") #or field(FLNK,"$(user):AllInterlocksRdbk.VAL PP")
but I don’t see the record $(user):AllInterlocksRdbk in the database, only "$(user):AllInterlocks.
Also, if you are going to put a field in a FLNK it should not be the .VAL field, but rather the .PROC field, i.e.
    field(FLNK,"$(user):AllInterlocksRdbk.PRO PP")
From: [email protected] [mailto:[email protected]] On Behalf Of Benoit
Sent: Tuesday, December 10, 2013 11:30 AM
To: EPICS mailing list
Subject: ai records: pool (SCAN) VS pull (FLNK) VS push (some examples)
Hi everybody,
I've been looking to obtain concrete examples of the following post: http://www.aps.anl.gov/epics/tech-talk/2012/msg02557.php in order to retrieve my data
I think I get it well for
  • pool: scan every 5 seconds the value of TempActRdbk
  • push: getting the value of CtrlManualStat read register when CtrlManualCmd write register is updated (this is done in the asynDriver).
However, I don't manage to use the forward link so that when I write in  CtrlManualCmd I want to obtain an updated value of AllInterlocks.
Can someone tell me how to perform, and what I am doing wrong in the use of FLNK:
record(bo, "$(user):CtrlManualCmd")
        field(DTYP ,"asynInt32")
        field(OUT  ,"@asyn($(PORT),$(ADDR),$(TIMEOUT))Ctrl_Manual")
record(bi, "$(user):CtrlManualStat")
        field(INP  ,"@asyn($(PORT),$(ADDR),$(TIMEOUT))Ctrl_Manual")
        field(SCAN ,"I/O Intr")
record(ai, "$(user):AllInterlocks")
        field(INP  ,"@asyn($(PORT),$(ADDR),$(TIMEOUT))Ilk_All")
record(ai, "$(user):TempActRdbk")
        field(INP  ,"@asyn($(PORT),$(ADDR),$(TIMEOUT))temp_act")
        field(SCAN ,"5 second")
Benoit RAT
ai records: pool (SCAN) VS pull (FLNK) VS push (some examples) Benoit
RE: ai records: pool (SCAN) VS pull (FLNK) VS push (some examples) Mark Rivers
Prev: RE: ai records: pool (SCAN) VS pull (FLNK) VS push (some examples) Mark Rivers
Next: Re: ai records: pool (SCAN) VS pull (FLNK) VS push (some examples) Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
