1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ai records: pool (SCAN) VS pull (FLNK) VS push (some examples)
To: "Johnson, Andrew N." <[email protected]>, Mark Rivers <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Tue, 10 Dec 2013 18:11:52 -0800
> Your AllInterlocks record has SCAN set to "I/O Intr" so forward-linking
> to it with a database link will not cause it to process. If you want it
> to process on both I/O Interrupt and from the forward link, you will
> have to make the forward-link a CA link, so Mark's suggestion above was
> almost right. Try this instead:
In the meantime, I am trying to wrap my head around a I/O Intr record whose processing is also triggered by a FLNK.
Although it can be programmed, in practical terms it doesn't make sense to me.
E
ai records: pool (SCAN) VS pull (FLNK) VS push (some examples) Benoit
RE: ai records: pool (SCAN) VS pull (FLNK) VS push (some examples) Mark Rivers
Re: ai records: pool (SCAN) VS pull (FLNK) VS push (some examples) Andrew Johnson
Prev: Re: ai records: pool (SCAN) VS pull (FLNK) VS push (some examples) Andrew Johnson
Next: pilatus detecotr modify FileName problem 洪春霞
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
