1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS Beast UI, Configure Item
To: John Dobbins <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 17 Dec 2013 16:46:40 -0500
Hello:
> Is this an issued related to Alarm RDB permissions?
No, it's not about RDB permissions. It's about the auth & auth, which is somewhat hard to configure, but in current versions of CSS, it's not as hard as it used to be.
For example, when you now click on the info of who's logged in in the status bar, you see detail of which permissions you have.
The plugins
> org.csstudio.platform.jaasAuthentication and
> org.csstudio.platform.jaasAuthentication.ui
have been replaced with org.csstudio.auth and org.csstudio.auth.ui, plus there's now the option to just use the 'current' user as the authenticated user, and file-based authorization, so it's much easier to get started.
I would suggest you get a newer source snapshot, and see http://cs-studio.sourceforge.net/docbook/css_book.pdf for it's Authentication & Authorization chapter.
Kay
On Dec 17, 2013, at 4:33 PM, John Dobbins <[email protected]> wrote:
> All,
> I have built CSS (from source version 3.1.6. In particular on  64 bit linux) and I have included in the CSS product the features for the Beast Alarm Handler UI as well as dummy Authorization.
> Specifically,
>  the CSS product depends on the
> org.csstudio.alarm .beast.ui.feature and
> and feature org.csstudio.sns.feature.core depends on
> I am able to run CSS (org.csstudio.basic.epics.product)  as an Eclipse application. Alarms Server is also running as well as the JMS server.
> The CSS Alarm perspective look and functions as expected except that when I right click on an item in Alarm Tree or in Alarm Table the "configure item" menu choice is always grayed out. I have logged in using dummy authorization.
> Do you have suggestions regarding what I may be doing wrong? Is this an issued related to Alarm RDB permissions?
> Regards and thanks,
> John Dobbins
> Cornell University
CSS Beast UI, Configure Item John Dobbins
Prev: CSS Beast UI, Configure Item John Dobbins
Next: RE: Zero length length requests, EPICS upgrades, and cothread michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: areaDetector driver for Point Grey FlyCapture2 SDK? Mark Rivers
