1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Zero length length requests, EPICS upgrades, and cothread
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Wed, 18 Dec 2013 07:20:53 +0000
> I'm not a user of cothread.catools either, but I think it might be
> useful to have cothreads.catools and pyepics have similar behaviors
> whenever possible.    I've been confused about what the correct
> behavior for waveforms should be too.
Hi Matt!
> >> QUESTION: What should be the correct *default* result length when
> >> using cothread to perform caget() or camonitor() on a waveform?
> >> A. The "natural" length, encoded as zero: this returns NORD elements
> >> on a .12 and above server, but NELM elements on older version of
> >> EPICS.  (This is the current default.)
> > I think you should stick with this meaning.
> >> B. The "full" length, which for a waveform is NELM elements.
> >> I am proposing to make the following *incompatible* change: the
> >> default result length (encoded by the 'count' parameter to 'caget'
> >> and 'camonitor') will change from 0 ("natural" length) to "full"
> >> length, and if the "natural" length is wanted it will be necessary to
> >> explicitly specify 'count=0' as an argument.
> >> Please shout if you think this is a bad idea...
> > Shout!
> Oh, Micheal's proposal is (mostly) exactly what pyepics ca.get() does.
>  It takes a count argument with a default value of None.  That is
> interpreted as "use ca_element_count() to figure out count".   One can
> pass in count=0 to get the natural length (NORD elements), but the
> default is the full array.
That's what I was in the middle of rewriting cothread to do when I sent this mail, but on reflection and thinking about Andrew's response, I've decided to keep cothread's current behaviour which is to default count to 0 with the behaviour we're discussion.
I also very much like Andrew's suggestion of making, in effect, this decision (a grotesque caricature of the real code):
	if ca_element_count(channel) > 1:
	    return numpy.array(data)
	else:
	    return scalar(data)
> Should the ca.get() be changed to have a default count of 0 (meaning,
> return NORD elements)?  I think that would mean the user has to
> explicitly do a ca_element_count() to get the full array, which does
> seem reasonable.
> That is, if we know that elements NORD through NELM-1 are not valid
> data then it seems better to not return them, unless the user
> explicitly asks for it.  Then again, I think it would be preferable to
> have uniform behavior.  Looking forward to hearing what the best
> approach should be...
It's a tricky one.  Looking like I'm probably sticking with count=0, which is going to disappoint my colleague with the array access problem!
Re: Zero length length requests, EPICS upgrades, and cothread Matt Newville
Zero length length requests, EPICS upgrades, and cothread michael.abbott
Re: Zero length length requests, EPICS upgrades, and cothread Andrew Johnson
Prev: RE: Zero length length requests, EPICS upgrades, and cothread michael.abbott
Next: RE: Zero length length requests, EPICS upgrades, and cothread michael.abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Zero length length requests, EPICS upgrades, and cothread Matt Newville
