1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Increasing scan rate to 10 kHz
To: Andrew Johnson <[email protected]>, Evgeniy <[email protected]>
Date: Wed, 08 Jan 2014 08:36:26 -0800
It should be noted that with RT_PREEMPT the real-time threads
all execute in *user-mode*. They can run side-by-side with other
low-priority stuff in the same process and still get scheduled as
needed, preempting any other (lower-priority) thread or process
with low latency. Hence it is not necessary to play special tricks
with putting high-priority code into kernel modules etc.
- Till
On 01/08/2014 08:20 AM, Till Straumann wrote:
On 01/07/2014 02:19 PM, Andrew Johnson wrote:
Periodic scans are quite complicated, since they rely on the
underlying operating system to implement a delay timer and reschedule
the scan thread after the specific delay has elapsed. Most OSs don't
provide high accuracy delay scheduling, so I don't expect we will ever
be able to run periodic scan threads at 10KHz. - Andrew
As a matter of fact I don't think that 10kHz periodic scans are a big
problem for something like RTEMS
or linux (with RT_PREEMPT) on a reasonably fast CPU.
I just used a simple 'clock_nanosleep' based loop (based on code by
windriver, modified by myself)
which does something like
while ( 1 ) {
      /* get current time */
        clock_gettime( CLOCK_MONOTONIC, &wakeup );
      /* compute wakeup time 100us from now   */
        timespec_add_100us( &wakeup );
      /* sleep until wakeup time      */
        clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &wakeup, NULL );
      /* see when we actually woke up */
        clock_gettime( CLOCK_MONOTONIC, &now );
      /* missed = now - wakeup        */
        timespec_diff( &missed, &now, &wakeup );
      compute_statistics( &missed );
for a bunch of threads (using the SCHED_FIFO scheduler).
On my laptop (vanilla kernel, no RT_PREEMPT) I observe worst-case
'missed' deadline of several milli-seconds
but even on that system the running average is between 5us..50us.
On a kernel patched with RT_PREEMPT I get a worst-case missed deadline
by ~10us (average around 3-4us)
after running for a few minutes (on a not heavily loaded intel core
i7-2655LE, 2.2 GHz).
I would expect RTEMS/vxWorks to even perform a bit better.
- Till
Re: Increasing scan rate to 10 kHz Andrew Johnson
Re: Increasing scan rate to 10 kHz Till Straumann
Prev: Re: A call to 'assert(capacity != 0)' by thread‏ Dirk Zimoch
Next: RE: Agilent 33522A Function / Arbitrary Waveform Generator tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Increasing scan rate to 10 kHz Till Straumann
Next: Re: Increasing scan rate to 10 kHz Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
