1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Failed to install ISR
To: 류수 <[email protected]>
Cc: [email protected]
Date: Wed, 15 Jan 2014 19:23:14 -0500
On 01/15/2014 06:48 PM, 류수 wrote:
I am using devlib2-2.4 and mrfioc2-2.0.1
Can you try with the development version of devlib2?  There have been some changes since 2.4 which might be relevant to your problem.
$ hg clone http://epics.hg.sourceforge.net/hgweb/epics/devlib2/
------------ 원본 메일 내용 ------------
보낸 사람 : "Michael Davidsaver"<[email protected]>
받는 사람 : [email protected]
메일 제목 : Re: Failed to install ISR
보낸 날짜 : Wed, 15 Jan 2014 10:47:56 -0500
What versions of mrfioc2 and devlib2 are you using?
On 01/15/2014 10:25 AM, 류수 wrote:
I am in trouble to initialize PMC-EVR using mrfioc2.
The PMC-EVR is attached to MV6100 which runs vxWorks 6.9.
The message says that "Failed to install ISR" so it seems that driver can't connect interrupt handler
to the PCI interrupt, but I don't know how to fix.
Would you help me out ?
Soo
cd "epics/modules/mrfioc2"
value = 0 = 0x0
ld < bin/vxWorks-ppc604/mrf.munch
value = 38203712 = 0x246f140 = '@'
dbLoadDatabase("dbd/mrf.dbd")
value = 0 = 0x0
mrf_registerRecordDeviceDriver(pdbbase)
value = 0 = 0x0
dbLoadRecords("db/iocAdminVxWorks.db", "IOC=mrftest")
Can't register 'system' command -- no command interpreter available.
value = 0 = 0x0
mrmEvrSetupPCI("PMC1",2,4,0)
Device PMC1  2:4.0
Using IRQ 80
PMC Out FP:3 FPUNIV:0 RB:0 IFP:1
PMC1 shuting down... complete
value = 0 = 0x0
dbLoadRecords("db/evr-pmc-230.db","SYS=PMC, D=PMC:1, EVR=PMC1")FWVersion 0x1100000
6
Found version 6
Wvalue = 0 = 0x0
Re:Re: Failed to install ISR 류수
Prev: Re:Re: Failed to install ISR 류수
Next: Re:Re: Failed to install ISR 류수
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
