Hi Michael,
FYI I looked up the mv6100 BSP earlier today; 80 is the standard vector number for the first PMC slot, which number the BSP will have placed in the relevant PCI config register at bus configuration time. I can't explain for sure why the BSP's intConnect() routine would be rejecting the request but it does have a mechanism present to check the vector against specific ranges for which it knows how to enable and disable the interrupt source. There might be some specific code to handle the PMC slots that I haven't looked at (because we haven't used PMC slots much here at the APS). Luckily the source code for this area is all visible in the BSP though, so it shouldn't be too hard to trace what's going on.
- Andrew
Sent from my iPad
> On Jan 15, 2014, at 8:50 PM, "Michael Davidsaver" <[email protected]> wrote:
> Could you add some debug code to vxworksDevPCIConnectInterrupt() to
> determine what number is actually passed to INUM_TO_IVEC() in
> CallPciIntConnect()? Also, can you say if a PCI interrupt translation
> table is provided for your BSP, and if so, is it is large enough to
> include interrupt 80?
> http://epics.hg.sourceforge.net/hgweb/epics/devlib2/file/8fabcca118fe/pciApp/os/vxWorks/devLibPCIOSD.c#l145
>> On 01/15/14 21:02, 류수 wrote:
>> I changed devlib2 to the development version but it still give me same
>> message.
>> ------------ 원본 메일 내용 ------------
>> *보낸 사람 :* "Michael Davidsaver"<[email protected]>
>> *받는 사람 :* "류수" <[email protected]>
>> *참 조 :* [email protected]
>> *메일 제목 :* Re: Failed to install ISR
>> *보낸 날짜 :* Wed, 15 Jan 2014 19:23:14 -0500
>>> On 01/15/2014 06:48 PM, 류수 wrote:
>>> I am using devlib2-2.4 and mrfioc2-2.0.1
>> Can you try with the development version of devlib2? There have
>> been some changes since 2.4 which might be relevant to your problem.
>> $ hg clone http://epics.hg.sourceforge.net/hgweb/epics/devlib2/
>>> *받는 사람 :* [email protected]
>>> *보낸 날짜 :* Wed, 15 Jan 2014 10:47:56 -0500
>>> What versions of mrfioc2 and devlib2 are you using?
>>>> On 01/15/2014 10:25 AM, 류수 wrote:
>>>> Hi,
>>>> I am in trouble to initialize PMC-EVR using mrfioc2.
>>>> The PMC-EVR is attached to MV6100 which runs vxWorks 6.9.
>>>> The message says that "Failed to install ISR" so it seems
>>>> that driver can't connect interrupt handler
>>>> to the PCI interrupt, but I don't know how to fix.
>>>> Would you help me out ?
>>>> Regards,
>>>> Soo
>>>> cd "epics/modules/mrfioc2"
>>>> value = 0 = 0x0
>>>> ld < bin/vxWorks-ppc604/mrf.munch
>>>> value = 38203712 = 0x246f140 = '@'
>>>> dbLoadDatabase("dbd/mrf.dbd")
>>>> value = 0 = 0x0
>>>> mrf_registerRecordDeviceDriver(pdbbase)
>>>> value = 0 = 0x0
>>>> dbLoadRecords("db/iocAdminVxWorks.db", "IOC=mrftest")
>>>> Can't register 'system' command -- no command interpreter
>>>> available.
>>>> value = 0 = 0x0
>>>> mrmEvrSetupPCI("PMC1",2,4,0)
>>>> Device PMC1 2:4.0
>>>> Using IRQ 80
>>>> PMC Out FP:3 FPUNIV:0 RB:0 IFP:1
>>>> PMC1 shuting down... complete
>>>> value = 0 = 0x0
>>>> dbLoadRecords("db/evr-pmc-230.db","SYS=PMC, D=PMC:1,
>>>> EVR=PMC1")FWVersion 0x1100000
>>>> 6
>>>> Found version 6
>>>> Wvalue = 0 = 0x0
- Re:Re: Failed to install ISR 류수
- Re: Failed to install ISR Michael Davidsaver
<2014>
2025
2026
<2014>
2025
2026
