1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn lock issue?
To: <[email protected]>, <[email protected]>
Date: Thu, 23 Jan 2014 10:02:25 -0600
Hi Mark,
On 01/23/2014 06:26 AM, Mark Davis wrote:
> Despite several "make clean", "make realclean", "make rebuild", etc
> commands issued at numerous levels in the tree (and even some manual
> deletions of files that still weren't being wiped or replaced), somehow
> I missed the fact that things (including, apparently asyn) were NOT
> recompiled, and I didn't discover that until I added some diagnostic
> printf's to the code (after which everything worked fine, because that
> DID cause it to recompile).
In the future you should try 'make clean uninstall' or 'make distclean'
to ensure that every built and installed object gets removed; none of
the other targets that you tried will delete the include, bin or lib
directories.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
asyn lock issue? Mark Davis
Re: asyn lock issue? Mark Davis
Prev: RE: SNL monitor and pvPutComplete Mooney, Tim M.
Next: Help with MEDM. Diego Henrique Dorta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn lock issue? Mark Davis
Next: CAJ and EPICS_CA_AUTO_ADDR_LIST Konrad, Martin
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
