1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget.c patch for dynamic array sizing
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 29 Jan 2014 10:03:06 +0100
On 27.01.2014 21:56, Andrew Johnson wrote:
Hi Bruce,
On 01/24/2014 06:32 PM, Bruce Hill wrote:
We've been trying to reduce network bandwidth on
CA image transfers by using ROI to reduce the required
data, and just noticed that the default for the caget
command line tool always fetches the full array, even
if NORD is less than NELM.
This happens because caget currently defaults to synchronous
get, and only the -c async option supports dynamic array sizing.
As async vs sync CA is a subtle distinction that doesn't matter for
most of our users, I've added an option to our caget to request
synchronous get and changed the default to async.
I think this could be useful for the broader community,
so here's a patch that does this.
I could accept using an environment variable to control the default
asyn/sync behaviour of the caget/caput tools, but I would be concerned
about breaking existing scripts that call them if we were to change
their behaviour without at least allowing sites to easily switch back to
the old default.
My personal preference would be for the catools programs to take
defaults from environment variables like GNU's GREP_OPTIONS variable.
Then it would be up to you to add something like
     export EPICS_CAGET_OPTIONS=-c
to your systems' shell configurations.
Ralph Lange is the maintainer for the catools programs though, so I'm
waiting for a response from him.
That proposal sounds reasonable.
I will add this to the commandline tools.
Do you think we will also need a generic EPICS_CATOOLS_OPTIONS variable honored by all catools?
~Ralph
Re: caget.c patch for dynamic array sizing Johnson, Andrew N.
caget.c patch for dynamic array sizing Bruce Hill
Re: caget.c patch for dynamic array sizing Andrew Johnson
Prev: RE: iocLog michael.abbott
Next: Re: iocLog Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget.c patch for dynamic array sizing Andrew Johnson
Next: Re: caget.c patch for dynamic array sizing Johnson, Andrew N.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
