1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Andor SDK3 Zyla
To: [email protected]
Date: Tue, 04 Feb 2014 09:04:38 -0500
Hello,
We use the Neo on SL6 (a RHEL rebuild). We have not had problems with the software end, but we have had some issues with the CameraLink card under Linux. It seems to work in some slots, but not others. I think the drivers is sensitive to something like a shared IRQ.
Phil Sorensen
CHESS
On 2/3/2014 2:22 PM, Pearson, Matthew R. wrote:
We have a Andor Zyla camera, that we plan to control via the existing areaDetector driver for the Andor SDK3 library. However, we're finding that the SDK3 doesn't work on 64-bit RHEL6 (Kernel 2.6.32). I've not had the chance to test the EPICS support yet, as this is purely an Andor issue - their example programs fail to run correctly.
So I'm just wondering if anyone else has an Andor sCMOS camera, that uses SDK3, and has it working under Linux. If so, please could you let us know the distribution and kernel version number?
The camera example programs work on Windows 7 64-bit. So if we can't get it working on Linux that will be our fall back solution.
Cheers,
Matt
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
RE: Andor SDK3 Zyla Mark Rivers
Andor SDK3 Zyla Pearson, Matthew R.
Prev: RE: Andor SDK3 Zyla Mark Rivers
Next: RE: Andor SDK3 Zyla Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
