Hi Ritu,
The devGpib device support is no longer the recommended best solution for this type of application, though it could probably work.
There are a couple of alternatives:
- StreamDevice In this case you want to take one message packet and set the values of 50 EPICS records from it. That is a little messy with StreamDevice, though again it could be done I think.
- asynPortDriver. This is what I would recommend. You write a driver based on the asynPortDriver C++ base class. In your constructor you define a parameter in your driver for each of the 50 values in your packet.
#define myInteger1ParamString "MY_INTEGER1"
#define myDouble1ParamString "MY_DOUBLE1"
#define NUM_PARAMS 50
myDriver::myDriver(const char *myPort, const char *tcpPort)
: asynPortDriver(myPort,
1, /* maxAddr */
NUM_PARAMS,
asynInt32Mask | asynFloat64Mask, /* Interface mask */
asynInt32Mask | asynFloat64Mask , /* Interrupt mask */
0, /* asynFlags. This driver does not block and it is not multi-device, so flag is 0 */
1, /* Autoconnect */
0, /* Default priority */
0) /* Default stack size*/
createParam(myInteger1ParamString, asynInt32, &myInteger1Param)
createParam(myInteger2ParamString, asynInt32, &myInteger2Param)
createParam(myDouble1ParamString, asynIFloat64, &myDouble1Param)
status = pasynOctetSyncIO->connect(tcpPort, 0, &pasynUser, NULL);
Your driver will launch a thread that does the following:
char buffer(100);
epicsInt8 intValue;
epicsFloat64 doubleValue;
while (1) {
status = pasynOctetSyncIO->read(pasynUser, ..., buffer, 100...) // Read TCP packet from your device
intValue = *(epicsInt8 *)&buffer[0]; // Extract 8-bit integer at byte 0 in buffer
setIntegerParam(myInteger1Param, intValue)
doubleValue = *(double *)&buffer[10]; // Extract double starting at byte 10 in buffer
setDoubleParam(myDouble1Param, doubleValue);
callParamCallbacks();
You create a database using asynInt32 and asynFloat64 device support. Your drvInfo strings in the INP links are the strings you defined in your driver:
record(longin, "MyInteger1") {
field(DTYP, "asynInt32")
field(INP, "@asyn($(PORT), 0, 1)MY_INTEGER1")
field(SCAN, "I/O Intr")
record(ai, "MyDouble1") {
field(DTYP, "asynFloat64")
field(INP, "@asyn($(PORT), 0, 1)MY_DOUBLE1")
You can look at the example in asyn/testAsynPortDriver/src/testAsynPortDriver.cpp to see how to write the driver and the database.
The only difference is that in your driver the thread will be calling pasynOctetSyncIO->read() to read the values from the remote TCP device.
Sent: Wednesday, February 12, 2014 11:19 PM
To: [email protected]; Mark Rivers
Subject: Re: Query on TCP IP
Dear Sir/Madam
I have establish connection using TCP asyn module by using and also receiving 100bytes TCP data, it is stored in pgpibDpvt->msg.
I am using following gbib command
static struct gpibCmd gpibCmds[]={
{@DSET_AI, GPIBCVITO, IB_Q_HIGH,0,0,10,10,tcpread,0,0,0,0,0},
and in tcp read funtion i am reading using
status=pasynOctet->read(asynOctetPvt,pasynUser,pgpibDpvt->msg,100,nchars,0)
along with other initialization command.
In the data there are 10 float numbers(i.e.40 bytes), 20 integer numbers (20 bytes) and remaining are Boolean (i.e 20bytes).
I have separated floats, integers and Booleans, now i want to assign this to PV. Kindly help me how to make various records/database (.db file), and how to assign segregated received value to process variable.
I am new in record set/process varible/db file, kindly give one example of each how received data will automatically linked with process variable and could able to reflect the received value in MEDM. (I am familiar with MEDM)
Regards
Ritu Sanjay Jain
On Wednesday, 12 February 2014 10:13 PM, RITU JAIN <[email protected]> wrote:
Dear Sir/Madam
I have establish connection using TCP asyn module, and also received 100bytes TCP data, it is stored in let assume msg->buf. In which 10 are the float (i.e.40 bytes), 20 are the integers (20 bytes) and remaining are Boolean (i.e 20bytes).
I have segregated floats, integers and Booleans, now i want to assign this to PV. Kindly help me how to make various records/database (.db file), and how to assign segregated received value to process variable.
I am very new in record set/process varible/db file, kindly give one example of each.
Regards
Ritu Jain
- RE: Query on TCP IP Emmanuel Mayssat
- Query on TCP IP RITU JAIN
- Re: Query on TCP IP RITU JAIN
CSS Archiving - non RDB PV Amien Crombie
Binary record that recover its value after changed Antonio Borondo
<2014>
2025
2026
<2014>
2025
2026
