1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC logging
To: "L. C. De Silva" <[email protected]>, <[email protected]>
Date: Mon, 17 Feb 2014 13:06:42 +0100
Hi Chanaka
On Saturday, February 15, 2014 19:56:34 L. C. De Silva wrote:
> make[3]: Entering directory
> `/home/sysuser/epics.3.14.12.1/fgt_sc/snmpApp/src/O.linux-x86' echo
> "../O.Common/modbus.dbd : ../Makefile" >> modbus.dbd.d
> Expanding dbd
> /home/sysuser/epics/base-3.14.12.3/bin/linux-x86/dbExpand  -I. -I..
> -I../O.Common -I../../../dbd -I/home/sysuser/epics/base-3.14.12.3/dbd
> -I/home/sysuser/epics/synApps_5_7/support/seq-2-1-13/dbd
> -I/home/sysuser/epics/synApps_5_7/support/asyn-4-21//dbd
> -I/home/sysuser/epics/soft/modules/caPutLog-3.3.3//dbd -o modbus.dbd
> ../modbusInclude.dbd perl
> /home/sysuser/epics/base-3.14.12.3/bin/linux-x86/makeIncludeDbd.pl
> caPutLogInclude.dbd Usage:
> 	makeIncludeDbd.pl infile1 [ infile2 infile3 ...] outfile
> Error: "makeIncludeDbd.pl caPutLogInclude.dbd": No input files
> specified make[3]: *** [../O.Common/caPutLogInclude.dbd] Error 2
 From the Makefile:
> # install devXxxSoft.dbd into <top>/dbd
> DBD += devSnmp.dbd
> DBD += modbus.dbd
> DBD += modbusSupport.dbd
> DBD += caPutLog.dbd
This tells make that it should generate a file named caPutLog.dbd (and
modbusSupport.dbd etc), which is probably not what you want. Instead you
want to *use* the existing dbd (e.g. the one from the caPutlog module)
to include it in your IOC's dbd file:
> # snmp.dbd will be made up from these files:
> snmp_DBD += base.dbd
> snmp_DBD +=  devSnmp.dbd
snmp_DBD += caPutLog.dbd
PS: you might want to send questions like this to [email protected]
-- it often turns out that the problem is not specific to the particular
module (as in this case).
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
Prev: Re: record processing time Vishnu Patel
Next: AW: EPICS/ModbusTCP communication with Rockwell Micro 850 PLC Mathes, Hermann-Josef (IKP)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS/ModbusTCP communication with Rockwell Micro 850 PLC Mark Rivers
Next: RE: record processing time Dalesio, Leo
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
