1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Asyn commands not found in Motor record WithAsyn example?
From: "Gomella, Andrew (NIH/NHLBI) [F]" <[email protected]>
Date: Tue, 18 Feb 2014 19:32:37 +0000
Hi Everyone,
I am having trouble figuring out whats causing this strange error I am encountering on one of my EPICS servers. (another server with similar versions of everything does not have this error). I am using the latest versions of asyn (4-22) and motor (6-8). I have made all modifications listed such that motor record builds its example application, including WithAsyn which is what I really need.
Now when I try and run an IOC with an included st.cmd file (with all relevant substitions made such as variable names made and the location of my motor) I receive errors that the commands are not found-
../../bin/linux-x86_64/WithAsyn st.cmd.AG_CONEX
#errlogInit(5000)
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocWithAsyn")
epicsEnvSet("TOP","/home/ipsuser/epics/support/motorR6-8")
epicsEnvSet("MOTOR","/home/ipsuser/epics/support/motorR6-8")
epicsEnvSet("SSCAN","/home/ipsuser/epics/support/sscan-2-9")
epicsEnvSet("ASYN","/home/ipsuser/epics/support/asyn4-22")
# Tell EPICS all about the record types, device-support modules, drivers,
# etc.
dbLoadDatabase("../../dbd/WithAsyn.dbd")
WithAsyn_registerRecordDeviceDriver(pdbbase)
### Motors
dbLoadTemplate "motor.substitutions.AG_CONEX"
# For Windows
#drvAsynSerialPortConfigure("serial1", "COM3", 0, 0, 0)
# For Linux
drvAsynSerialPortConfigure("serial1", "/dev/stages/cc", 0, 0, 0)
asynSetOption("serial1",0,"baud","921600")
st.cmd.AG_CONEX -- Line 15 -- Command asynSetOption not found.
asynSetOption("serial1",0,"bits","8")
st.cmd.AG_CONEX -- Line 16 -- Command asynSetOption not found.
asynSetOption("serial1",0,"stop","1")
st.cmd.AG_CONEX -- Line 17 -- Command asynSetOption not found.
asynSetOption("serial1",0,"parity","none")
st.cmd.AG_CONEX -- Line 18 -- Command asynSetOption not found.
asynSetOption("serial1",0,"clocal","Y")
st.cmd.AG_CONEX -- Line 19 -- Command asynSetOption not found.
asynSetOption("serial1",0,"crtscts","N")
st.cmd.AG_CONEX -- Line 20 -- Command asynSetOption not found.
asynOctetSetInputEos("serial1",0,"\r\n")
st.cmd.AG_CONEX -- Line 22 -- Command asynOctetSetInputEos not found.
asynOctetSetOutputEos("serial1",0,"\r\n")
st.cmd.AG_CONEX -- Line 23 -- Command asynOctetSetOutputEos not found.
asynSetTraceIOMask("serial1", 0, 2)
st.cmd.AG_CONEX -- Line 25 -- Command asynSetTraceIOMask not found.
#asynSetTraceMask("serial1", 0, 9)
# Load asyn record
dbLoadRecords("/home/ipsuser/epics/support/asyn4-22/db/asynRecord.db", "P=dell:,R=serial1,PORT=serial1, ADDR=0,OMAX=256,IMAX=256")
Record "dell:serial1" is of unknown type "asyn" - Error at or before ")" in file "/home/ipsuser/epics/support/asyn4-22/db/asynRecord.db" line 1
I feel like I have exhausted any ideas I have about what may be causing this, so any help will be appreciated.
Andrew Gomella
Prev: RE: control knobs to a new control system Emmanuel Mayssat
Next: RE: Asyn commands not found in Motor record WithAsyn example? Gomella, Andrew (NIH/NHLBI) [F]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fwd: epics base with MinGW-w64 Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
