1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Epics/Raspberry Pi data acquisition
To: John Dobbins <[email protected]>, EPICS mailing list <[email protected]>
Date: Thu, 20 Feb 2014 15:41:57 -0800
Thanks John,
The past year, I left my RaspPi and Beagleboard in the drawer and started playing with the papilio board
http://papilio.cc/.You probably want to have a look at it! This solution is probably better than what you have + you won't have to deal with the missing ~ $20 FTDI.
Ultimately I have my eyes on the Xilinx ZynQ
http://zedboard.org/
http://www.xilinx.com/training/zynq/index.htm
which offer the combination ARM + FPGA for ~ $400 / dev board
which is certainly more expensive than the RaspPi+FPGA solution, but more flexible and higher performance. I also predict that Intel + Altera will offer a similar SOC soon.
In the same space, I am looking at PoE and Qt Embedded.
Check this out
http://www.megaleecher.net/Raspberry_Pi_POE#axzz2tuLQEoyv
http://www.ics.com/blog/building-qt-and-qtwayland-raspberry-pi#.UwaOhsv8NhF
https://gitorious.org/raspberry-qt/raspberry-qt/source/3c2ed05270137644300cde3b22829380698ff9a9:README.txt
Now imagine that you plug your embedded IOC, PVs are available but GUI are also deployed on a distributed file-system.
Cheers,
E
In the end I was, with relatively little work, able to write some HDL code for the FPGA, program the FPGA from the Pi over the USB connection, and then connect an IOC on the Pi to the FPGA via the USB connection, thus creating  a simple stand alone data acquisition instrument with built-in IOC.
RE: Epics/Raspberry Pi data acquisition Emmanuel Mayssat
Re: Epics/Raspberry Pi data acquisition Steve Shoaf
Epics/Raspberry Pi data acquisition John Dobbins
Prev: Re: Fwd: epics base with MinGW-w64 Andrew Johnson
Next: RE: CSS BOY - EDL to OPI Converter development progress? Zelazny, Michael Stanley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Epics/Raspberry Pi data acquisition John Dobbins
Next: RE: Epics/Raspberry Pi data acquisition Emmanuel Mayssat
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
