Hi Andrew,
I forgot the second failure it incurs: failed when building as
shared-libraries.
This is because src\catools\Makefile asks to build "tool_lib.c" as a
private static library.
And in 3.15.0.1 src\ca\client\tools\Makefile, this has been fixed by
linking directly the object file.
I replaced the Makefile with the one in 3.15.0.1 and it built with
success.
Best
Xiaoqiang
-----Original Message-----
[mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Freitag, 21. Februar 2014 00:08
To: [email protected]
Subject: Re: Fwd: epics base with MinGW-w64
Hi Xiaoqiang,
I tried changing "if defined(_DLL)" into "if !defined(EPICS_DLL_NO)" in
shareLib.h but it does not fix all cases and breaks some builds.
With that change included and building statically, several of the
network-related test programs that come with Base fail badly for me
(type 'make runtests' in the base-3.14.12.4 top directory to run them
yourself). I tried them with both the Microsoft and MinGW compilers,
with the same results, e.g.:
> blockingSockTest.exe
> A call to 'assert(this->sock != INVALID_SOCKET)'
> by thread 'win148' failed in ..\blockingSockTest.cpp line 172.
> EPICS Release EPICS R3.14.12.4-DEV $$Date$$.
> Local time is 2014-02-20 12:52:53.543946691 Ame Please E-mail this
> message to the author or to [email protected] Calling
> epicsThreadSuspendSelf()
The change also breaks the shared-library builds using the Microsoft
compiler, so I can't include it in the shipped version of Base.
As Peter mentioned, a comprehensive fix has been implemented in the 3.15
development version of Base, but 3.15 has not been released for
production use yet.
- Andrew
On 02/20/2014 02:47 AM, Xiaoqiang Wang wrote:
> For the archive purpose, I forward this answer from Peter Heesterman.
> Begin forwarded message:
>> From: "Heesterman, Peter J" <[email protected]>
>> Subject: RE: epics base with MinGW-w64
>> Date: 18 Feb 2014 15:10:42 GMT+1
>> To: "Wang Xiaoqiang" <[email protected]>
>> Hi Wang,
>> You are correct in saying that the _DLL macro is wrongly used in
sharelib.h - it is a conceptual error, meaning as it does that code is
being DLL-linked to Microsoft's VS libraries.
>> The EPICS_DLL_NO macro is correct to say that code is being built
statically to EPICS user libraries.
>> It has been corrected, for later releases.
>> Cheers,
>> Peter.
>> From: [email protected]
>> [mailto:[email protected]] On Behalf Of Wang Xiaoqiang
>> Sent: 18 February 2014 12:13
>> To: epics
>> Subject: epics base with MinGW-w64
>> Hi core developers,
>> Sorry this is a long post and the question at the very end.
>> I am using MinGW- w64 (http://mingw-w64.sourceforge.net/) on a
Windows 7 64bit PC to compile base 3.14.12.4.
>> It builds all OK by default. It stops with errors if configured to
build statically.
>> make[1]: Entering directory
`C:/epics/base-3.14.12.4-VC9/src/toolsComm/antelope/O.windows-x64-mingw'
>> gcc -c -D_MINGW -O3 -Wall -m64 -DEPICS_DLL_NO
>> -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/WIN32
>> -I../../../../include ../main.c
>> g++ -o antelope.exe -static
>> -LC:/epics/base-3.14.12.4-VC9/lib/windows-x64-mingw -m64
>> closure.o error.o lalr.o lr0.o main.o mkpar.o output.o reader.o
>> skeleton.o symtab.o verbose.o warshall.o -lCom -lws2_32
>> main.o:main.c:(.text.startup+0x2a6): undefined reference to
`__imp_epicsTempFile'
>> collect2.exe: error: ld returned 1 exit status
>> make[1]: *** [antelope.exe] Error 1
>> make[1]: Leaving directory
>> .windows-x64-mingw'
>> make: *** [install.windows-x64-mingw] Error 2
>> Looking at base-3.14.12.4-VC9/include/shareLib.h, it is apparently
somewhere '_DLL' has be defined.
>> And indeed it is that MinGW-w64 always has '_DLL' defined in
>> '_mingw.h',
>> /* We have to define _DLL for gcc based mingw version. This define is
set
>> by VC, when DLL-based runtime is used. So, gcc based runtime just
have
>> DLL-base runtime, therefore this define has to be set.
>> As our headers are possibly used by windows compiler having a
static
>> C-runtime, we make this definition gnu compiler specific here. */
>> #if !defined (_DLL) && defined (__GNUC__) #define _DLL #endif
>> So far the fault is on the side of MinGW-w64.
>> But I have a question about the valid use of '_DLL' macro in
'shareLib.h'
>> According to MSDN, _DLL is defined when epics is built to DLL
libraries, otherwise not.
>> It is perfectly fine if both client program and epics base are built
statically or dynamically.
>> If one wants to mix them, there is the problem.
>> I often need to compile my python extensions (DLLs by its essence) to
link to EPICS statically.
>> In such cases, _DLL is defined because the "client program" is
compiled to DLL not the "EPICS base libraries".
>> This will cause confusion, I workaround it by undefine _DLL macro.
>> So now it comes to my question: since macro EPICS_DLL_NO is the only
indication whether EPICS base is built statically or not, is it valid to
use it instead of _DLL in shareLib.h ......
>> # else
>> # if not defined(EPICS_DLL_NO) /* this indicates that we are
being
>> compiled to call DLLs */
>> # define epicsShareExtern __declspec(dllimport) extern
>> # define epicsShareClass __declspec(dllimport)
>> # define epicsShareFunc __declspec(dllimport)
>> # else
>> # define epicsShareExtern extern
>> # endif
>> Best
>> Xiaoqiang
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: Fwd: epics base with MinGW-w64 Andrew Johnson
- Fwd: epics base with MinGW-w64 Xiaoqiang Wang
RE: Fwd: epics base with MinGW-w64 Wang Xiaoqiang
RE: Epics/Raspberry Pi data acquisition Emmanuel Mayssat
<2014>
2025
2026
<2014>
2025
2026
