1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: New version of LabVIEW-EPICS-interface CA Lab 1.5.0.1 can create new EPICS PVs now
To: tech-talk <[email protected]>
Date: Mon, 24 Feb 2014 16:19:52 +0100
We are happy to bring you the improved version of our
LabVIEW-EPICS-interface CA Lab 1.5.0.1!
You can create new EPICS PVs and start a Soft IOC instance out of
LabVIEW now!
We have updated our website and have new examples to getting started.
http://www-csr.bessy.de/control/SoftDist/CA_Lab/
Change-log of CA Lab
V1.5.0.1 (Released: February 2014)
  +++ New server component! +++
  + Configure and start an external "soft IOC shell" instance directly
    out of LabVIEW (for Windows only, Linux users really doesn't need it)
  + New VI "CaLabInfo" to show:
                 current (used) EPICS environment variables
                 internal EPICS PV cache of CA Lab
  # Error code for success is 0 now instead of 1
  # Error codes are in user error code range now (7008-7496)
    Ca Lab error {7008-7472} - 7000 = Channel Access error code
  # Shows more error messages
  # Solves problems with restarted VIs
  # caLabGet: Solves problems with empty PV name array
  # Removes delayed termination of VIs
    (found a better way for safe termination)
  # PV cache and subcriptions are running until all CA Lab VIs are closed
    (stopped VIs have ongoing PV monitors for quick restart)
  # Improved Linux compatibility
  # EPICS base 3.14.12.4
  Known problems (for Linux users only!!!)
  Linux + current LabVIEW™ version: The event function is broken. (NI
  confirmed the problem and looks for a solution.) The problem is in the
  development enviroment only. If you build an executible, all is fine.
(NI 2014-02-24: "The problem is expected to be fixed with the version LV
2014.")
All suggestions and comments are welcome!
Cheers
Carsten
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Prev: Re: epics on beaglebone D Peter Siddons
Next: Re: procServ softIOC server - V2.6.0 released Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
