1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Monitoring whether an IP device is connected or not
To: [email protected], [email protected]
Date: Thu, 27 Feb 2014 11:29:17 +0000
Hi Dohn,
This actually sounds exactly what I want to achieve! Please let us know you're releasing it. I'm sure I'm not the only one that would fin it useful!
David
I've written an EPICS record for doing something similar.  Every ten seconds (or whatever the SCAN rate it), it sends a UDP packet to a specified address and port.  This packet contains a heartbeat counter, boot time (recorded at record initialization, used as unique incarnation identifier), current time, and IOC name.  The IP address is gotten from the packet itself.  On the remote server, the UDP packets are collected by a daemon into a database to monitor the IOCs.
The record is running on over 40 beamline IOCs here at the APS (about half of what is planned).  I plan on releasing this record and support code soon, but am still refining a few things (there are a few more features I didn't describe).
Dohn
Re: Monitoring whether an IP device is connected or not Pearson, Matthew R.
Prev: Re: Monitoring whether an IP device is connected or not David Michel
Next: Re: newline in IOCSH_PS1 value Mark Davis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Monitoring whether an IP device is connected or not Dohn Arms
Next: Re: Monitoring whether an IP device is connected or not Pearson, Matthew R.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
