1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: newline in IOCSH_PS1 value
To: [email protected]
Cc: epics <[email protected]>
Date: Thu, 27 Feb 2014 08:25:54 -0800
You’re trying this on linux?
I just tried:
makeBaseApp.pl -t example example
makeBaseApp.pl -t example -i example
make
cd iocBoot/iocexample/
../../bin/linux-x86_64/example st.cmd
export IOCSH_PS1=“FOO
BAR> "
and got
## Start any sequence programs
#seq sncExample, "user=enorumHost"
FOO
BAR>
I didn’t type anything fancy on the export line — just a <return>.
I then added this line to the startup script:
epicsEnvSet IOCSH_PS1 "$(PROMPT)"
and
export PROMPT="ONE LINER> "
ONE LINER>
export PROMPT="TWO
> LINER> "
TWO
LINER>
The fact that you get a complaint about PROMPT being undefined makes me think that there’s something weird with your linux shell — that it’s not actually passing on the environment properly.
On Feb 27, 2014, at 8:03 AM, Mark Davis <[email protected]> wrote:
Don't know why it doesn't work for for me.
I tried this first just using the name IOCSH_PS1 for my bash environment variable, which didn't work.
Figuring that the IOCSH_PS1 value might get some special treatment, or that something in the scripts we use to lauch the IOC shell are doing something of their own, I tried this:
___________________________________________
In my bash shell, before launching the IOC shell:
davis-pc:/home/epics/R3.14.12.2/apps/mdlinux/iocBoot/iocFrib> export PROMPT=$'\nmdlinux> '
  OR
davis-pc:/home/epics/R3.14.12.2/apps/mdlinux/iocBoot/iocFrib> export PROMPT="    <--- typed Ctl+V, Ctl+J
mdlinux> "
Both of which produce the same effect:
davis-pc:/home/epics/R3.14.12.2/apps/mdlinux/iocBoot/iocFrib> env
PROMPT=
mdlinux>
   OR
davis-pc:/home/epics/R3.14.12.2/apps/mdlinux/iocBoot/iocFrib> set | grep PROMPT
In the st.cmd file:
epicsEnvSet("IOCSH_PS1", "$(PROMPT)")
   which produces the error:
macLib: macro PROMPT is undefined (expanding string epicsEnvSet("IOCSH_PS1", "$(PROMPT)"))
  and I also tried:
epicsEnvSet IOCSH_PS1 $(PROMPT)
macLib: macro PROMPT is undefined (expanding string epicsEnvSet IOCSH_PS1 $(PROMPT))
Is there something special you have to do to get a particular bash environment variable to show up in the EPICS IOC shell?  If not, what determines which ones show up and which ones don't?
Mark Davis
Eric Norum
[email protected]
Re: newline in IOCSH_PS1 value Mark Davis
Re: newline in IOCSH_PS1 value Eric Norum
Prev: Re: newline in IOCSH_PS1 value Mark Davis
Next: Re: newline in IOCSH_PS1 value Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: newline in IOCSH_PS1 value Eric Norum
Next: Re: newline in IOCSH_PS1 value Mark Davis
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
