1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Battling to start archive.engine on Postgresql db
To: Ivan Kohler <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 4 Mar 2014 09:14:25 -0500
Hi:
On Mar 3, 2014, at 5:17 PM, Ivan Kohler <[email protected]> wrote:
> I managed to start CSS archive.engine on a MySQL db,
Good, so at least something is working.
> In Eclipse I edited:
> org.csstudio.archive.engine
>   plugin_customization.ini file
> org.csstudio.archive.rdb/url=jdbc:postgresql://localhost:5432/archive
> and
> org.csstudio.archive.engine.rdb
>   preferences.ini file
>     # Postgresql example
> url=jdbc:postgresql://localhost/archive?rewriteBatchedStatements=true
You should leave the "preferences.ini" files unchanged. They contain the defaults and explanation of available settings.
To specify what you actually want to use, you _could_ edit the plugin_customization.ini in the archive engine sources, but better would be to not edit any sources and instead provide the path to _your_ plugin_customization.ini file on the command-line:
 ArchiveEngine -pluginCustomization /path/to/my/settings.ini -engine Demo ….
See also "Hierarchical Preferences" in the CSS Guide, http://cs-studio.sourceforge.net/docbook/ch06.html
> Caused by: java.lang.NullPointerException
>     at
> org.csstudio.archive.rdb.RDBArchivePreferences.getSchema(RDBArchivePreferences.java:37)
Strange.
For Postgres you should configure the "schema" to be empty, just as you did with MySQL.
So your settings.ini would contain:
# Set schema to empty
org.csstudio.archive.rdb/schema=
The error message suggests that the 'schema' is not defined at all, which could only happen if you deleted it from the org.csstudio.archive.rdb/preferences.ini as well as org.csstudio.archive.engine/plugin_customization.ini.
Kay
Re: Battling to start archive.engine on Postgresql db Ivan Kohler
Prev: new improved version of caQtDM Mezger Anton Christian
Next: #personal#Fw: Error in feching PV from CSS Swati Soni2
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Battling to start archive.engine on Postgresql db Ivan Kohler
Next: Re: Battling to start archive.engine on Postgresql db Ivan Kohler
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
