1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Battling to start archive.engine on Postgresql db
To: tech-talk <[email protected]>
Date: Tue, 04 Mar 2014 17:40:51 +0200
Hi All,
I seem to have found the problem.
It is related to user rights, when I changed
from
org.csstudio.archive.rdb/user=archive
org.csstudio.archive.rdb/password=$archive
to
org.csstudio.archive.rdb/user=postgres
org.csstudio.archive.rdb/password=<my_password>
in
org.csstudio.archive.engine ,    'plugin_customization.ini'  file
then the archive.engine started
I was a little surprised as I thought user archive was created in the postgres_schema.txt.
I am a bit new to postgresql to know what I should do about it.
Ivan Kohler,
iThemba Labs, South Africa
-------- Original Message --------
Subject: Battling to start archive.engine on Postgresql db
Date: Tue, 04 Mar 2014 00:17:19 +0200
Hi All,
I managed to start CSS archive.engine on a MySQL db, now I am trying to
get it started on a Postgresql db.
I am on a PC running Ubuntu 1204 using:
Java: JDK SE Dev Kit 7.51
Eclipse fro RCP and RAP Developers ver 1.4.2
SNS Sources 3.2.14
I installed postgresql 9.1 and loaded the schema with:
   sudo -u postgres psql <
~/css/sources/org.csstudio.archive.rdb/dbd/postgres_schema.txt
So smpl_eng has the Demo engine in it:
1, Demo, Demo Engine, http://localhost:4812
I edited postgresql's pg_hba.conf file
      host    all             all 127.0.0.1/32            md5
      host    all             all             10.0.0.1/24     md5  #
Added this line
In Eclipse I edited:
  plugin_customization.ini file
org.csstudio.archive.rdb/url=""
and
org.csstudio.archive.engine.rdb
  preferences.ini file
    # Postgresql example
url=""
Before Launching the ArchiveEngine.product I added
Program Arguments using the 'Launching' tab
        -engine Demo
        -port 4812
On Launching I got the following in the Eclipse Console:
2014-03-03 23:11:01.753 INFO [Thread 1]
org.csstudio.archive.engine.Application (start) - Archive Engine
3.2.14.qualifier
2014-03-03 23:11:01.896 INFO [Thread 1]
org.csstudio.archive.engine.server.EngineServer (<init>) - Engine HTTP
Server on http://localhost:4812/main
2014-03-03 23:11:01.897 INFO [Thread 1]
org.csstudio.archive.engine.Application (start) - Reading configuration
'Demo'
2014-03-03 23:11:01.939 SEVERE [Thread 1]
org.csstudio.archive.engine.Application (start) - Cannot read configuration
org.eclipse.core.runtime.CoreException: Plug-in
"org.csstudio.archive.config.rdb" was unable to instantiate class
"org.csstudio.archive.config.rdb.RDBArchiveConfig".
    at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
    at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:186)
    at
org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
    at
org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
    at
org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
    at
org.csstudio.archive.config.ArchiveConfigFactory.getArchiveConfig(ArchiveConfigFactory.java:37)
    at org.csstudio.archive.engine.Application.start(Application.java:164)
    at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
    at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
    at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
    at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
    at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
    at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:606)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
    at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.lang.NullPointerException
    at
org.csstudio.archive.rdb.RDBArchivePreferences.getSchema(RDBArchivePreferences.java:37)
    at
org.csstudio.archive.config.rdb.RDBArchiveConfig.<init>(RDBArchiveConfig.java:66)
    at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native
Method)
    at
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
    at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
    at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
    at java.lang.Class.newInstance(Class.java:374)
    at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
    ... 18 more
Any comments would be greatly appreciated.
Best Regards,
Ivan Kohler
iThemba LABS,
South Africa
Battling to start archive.engine on Postgresql db Ivan Kohler
Prev: #personal#Fw: Error in feching PV from CSS Swati Soni2
Next: Re: #personal#Fw: Error in feching PV from CSS David Michel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Battling to start archive.engine on Postgresql db Ivan Kohler
Next: EPICS RE: epics on beaglebone Keith Parker
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
