1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building the Archive Engine
To: Nicoletta Petrella <[email protected]>
Date: Thu, 6 Mar 2014 17:11:27 -0500
Hi:
The error regarding org.eclipse.jetty means: You're not using Eclipse 3.7.2 as the target platform.
The CSS sources are currently based on Eclipse 3.7.2.
Feel free to use the binaries from https://ics-web.sns.ornl.gov/css/updates/apps<https://ics-web.sns.ornl.gov/css/updates/apps/?C=M;O=D>.
They're build from the sources with matching tags, like "SNS3.2.15" for archive_engine_3.2.15…
They're the binaries that we use at the SNS, so we only have those binaries for the architectures that we need, like Linux for the archive engine.
Kay
On Mar 6, 2014, at 4:27 PM, Nicoletta Petrella <[email protected]<mailto:[email protected]>> wrote:
Dear all,
I'm trying to built the Archive Engine throught Eclipse, but I'm getting several errors trying to run org.csstudio.archive.engine/ArchiveEngine.product. It looks like I'm missing the packages org.eclipse.jetty....
In a previous post I have read that the best is to start with a matching set of sources and Eclipse. How can I undestand if souces and Eclipse are matching?
Instead of build the Archive Engine and the Archive Configuration Tool thought Eclipse can I use the executable files in
https://ics-web.sns.ornl.gov/css/updates/apps/?C=M;O=D ? Which is the difference?
Thank you very much.
Nicoletta
..0==/--\==0....
....../___\........
......_| |_.........
Building the Archive Engine Nicoletta Petrella
Prev: Building the Archive Engine Nicoletta Petrella
Next: MAXv model-3 - error reading axis position after 5 attempts Luchini, Kristi L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
