1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using a Waveform record (char type representing a String) as input to an aSub record
To: David Michel <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Mon, 10 Mar 2014 10:57:03 -0700
<pedantic mode>
Minor point — the myString declaration and cast should be
	char *
not
	char **
<pedantic mode/>
On Mar 10, 2014, at 9:27 AM, David Michel <[email protected]> wrote:
> Hi All,
> I'm using a Waveform record of type char to represent a string (not using a  Stringin or Stringout record since this string has more than 40 characters).
> That works well and I can easily put a string into this record such with caput -a and read it back with caget -s
> Now, I need to use this string in an aSub record but I'm having difficulties in doing so.
> char ** myString;
> myString = (char **) precord->a;
> printf("%s\n",myString);
> The results of the printf statement shows only the first character of the string in ASCII.
> Any idea of I can solve this?
> Many thanks
> David
Eric Norum
[email protected]
Re: Using a Waveform record (char type representing a String) as input to an aSub record Benjamin Franksen
Using a Waveform record (char type representing a String) as input to an aSub record David Michel
Prev: Re: Using a Waveform record (char type representing a String) as input to an aSub record Andrew Johnson
Next: help! can the epics monitor many pv in the same time,thanks zgang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Using a Waveform record (char type representing a String) as input to an aSub record Benjamin Franksen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
