1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: help! can the epics monitor many pv in the same time,thanks
To: EPICS Tech Talk <[email protected]>
Date: Tue, 11 Mar 2014 11:48:01 +0000
Is the question concerning the number of channels that can be monitored and archived (which as Leo said, is very large, into the many thousands), or are you asking specifically about ‘simultaneous monitoring’, grabbing many channels at exactly the same point in time?
EPICS can acquire and archive many, many channels, but each channel will be acquired at -slightly- different time.  As far as I know, you can’t do something like a triggered, simultaneous acquisition of a number of channels (say, 50…100) at precisely the same point in time without specific hardware capable of performing that function.  There are many devices (both commercially available, and custom manufactured) that can be interfaced to the EPICS system that can do that function, and provide that information to EPICS.
Later-
David Dudley
On Mar 11, 2014, at 6:59 AM, Ralph Lange <[email protected]> wrote:
Adding some links...
Hope this gets you started,
~Ralph
On Tue Mar 11 2014 11:29:27 GMT+0100 (CET), Dalesio, Leo
There are archiver appliances that are monitoring 10's of thousands of channels.
[1, 2, 3]
Care has to be taken about the rate of these monitors. Please read the EPICS Record Reference Manual
[4]
regarding how to deadband monitors for archiving alarms and value monitors. Please read the Application Developers Guide
[5]
and Channel Access Reference Manual
[6]
for ways to monitor and deal with managing these monitors.
[1] http://sourceforge.net/projects/epicschanarch/
[2] http://controlsystemstudio.org/
[3] http://epicsarchiverap.sourceforge.net/
[4] https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14
[5] http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide.pdf
[6] http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html
help! can the epics monitor many pv in the same time,thanks zgang
RE: help! can the epics monitor many pv in the same time,thanks Dalesio, Leo
Re: help! can the epics monitor many pv in the same time,thanks Ralph Lange
Prev: Re: Using a Waveform record (char type representing a String) as input toan aSub record David Michel
Next: Registration ONLINE - Next meeting of the EPICS Collaboration at IMP Lanzhou China from 19 to 23 May 2014 Yuan He
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: help! can the epics monitor many pv in the same time,thanks Ralph Lange
Next: Re: Using a Waveform record (char type representing a String) as input toan aSub record David Michel
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
