1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Another build-system bug in 3.14.12
To: Benjamin Franksen <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 12 Mar 2014 15:50:25 +0000
Sorry, my second paste was wrong.
Corrected version.
Hi Ben,
Here is how I have done this.
- Create an os/$(OS_CLASS) subdirectory.
For example:
corvette:areaDetector/ADBinaries/hdf5Support>ls os/WIN32/
COPYING       H5DSpublic.h  H5FDcore.h    H5FDmpi.h       H5FDpublic.h   H5Fpublic.h   H5LTpublic.h  H5PTpublic.h  H5TBpublic.h  H5overflow.h    H5public.h
H5ACpublic.h  H5Dpublic.h   H5FDdirect.h  H5FDmpio.h      H5FDsec2.h     H5Gpublic.h   H5Lpublic.h   H5Ppublic.h   H5Tpublic.h   H5pubconf.h     H5version.h
H5Apublic.h   H5Epubgen.h   H5FDfamily.h  H5FDmpiposix.h  H5FDstdio.h    H5IMpublic.h  H5MMpublic.h  H5Rpublic.h   H5Zpublic.h   H5pubconf_32.h  hdf5.h
H5Cpublic.h   H5Epublic.h   H5FDlog.h     H5FDmulti.h     H5FDwindows.h  H5Ipublic.h   H5Opublic.h   H5Spublic.h   H5api_adpt.h  H5pubconf_64.h  hdf5_hl.h
Then your Makefile can have this:
# OS-specific files in os/ARCH
INC_WIN32 += H5ACpublic.h
INC_WIN32 += H5Apublic.h
INC_WIN32 += H5Cpublic.h
INC_WIN32 += H5DSpublic.h
INC_WIN32 += H5Dpublic.h
INC_WIN32 += H5Epubgen.h
INC_WIN32 += H5Epublic.h
INC_WIN32 += H5FDcore.h
INC_WIN32 += H5FDdirect.h
INC_WIN32 += H5FDfamily.h
INC_WIN32 += H5FDlog.h
INC_WIN32 += H5FDmpi.h
This works fine with standard base I believe, including with "make -j".
From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
Sent: Wednesday, March 12, 2014 10:48 AM
To: Benjamin Franksen; [email protected]
Hi Ben,
For example:
From: [email protected] [[email protected]] on behalf of Benjamin Franksen [[email protected]]
Sent: Wednesday, March 12, 2014 10:35 AM
To: [email protected]
Subject: Another build-system bug in 3.14.12
Hi
I tried to fix the INC_<osclass> problem "by hand" like this:
ifeq ($(OS_CLASS),vxWorks)
inc: $(INSTALL_INCLUDE)/os/$(OS_CLASS)/bla.h
endif
instead of defining INC_vxWorks. This seems to work.
Now, in my real application the build was still broken, but only when
using parallel make i.e. make -j. I reproduced this in my cut-down
example with the following Makefile:
TOP = ..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
LIBRARY_IOC += bla
bla_SRCS += bla.c
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
bla.h:
        sleep 1
        echo "struct x {int y; };" > bla.h
(The bla.c is trivial and includes bla.h).
This fails with
franksen@tiber: ~/tmp/inc-bug > make -sj distclean && make -sj
../bla.c:1:17: fatal error: bla.h: No such file or directory
compilation terminated.
make[2]: *** [bla.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [install.linux-x86] Error 2
make: *** [bugApp.install] Error 2
However, it works if I add an explicit dependency in the Makefile:
bla.o: bla.h
Inspecting the generated dependency makefile snippets shows why the
parallel build fails: they are empty:
franksen@tiber: ~/tmp/inc-bug > find -name *.d
./bugApp/O.RTEMS-mvme2100/bla.d
./bugApp/O.RTEMS-mvme5500/bla.d
franksen@tiber: ~/tmp/inc-bug > cat ./bugApp/O.RTEMS-mvme2100/bla.d
franksen@tiber: ~/tmp/inc-bug > cat ./bugApp/O.RTEMS-mvme5500/bla.d
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Re: Another build-system bug in 3.14.12 Andrew Johnson
Another build-system bug in 3.14.12 Benjamin Franksen
RE: Another build-system bug in 3.14.12 Mark Rivers
Prev: RE: Another build-system bug in 3.14.12 Mark Rivers
Next: Software Engineer Position at Advanced Photon Source Schwarz, Nicholas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Another build-system bug in 3.14.12 Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
