1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Installing EPICS on the Raspberry Pi
To: Torsten Bögershausen <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 17 Mar 2014 08:18:42 -0500
Torsten:
Thanks for the comments:
These are equivalent.  I was not aware of the second form:
mint14@vb-mint14-64:~$ echo $SHELL
/bin/bash
mint14@vb-mint14-64:~$ echo `/home/mint14/Apps/epics/base-3.14.12.3/startup/EpicsHostArch`
linux-x86_64
mint14@vb-mint14-64:~$ echo $(/home/mint14/Apps/epics/base-3.14.12.3/startup/EpicsHostArch)
linux-x86_64
You are correct. The correct /bin/ delimiters to use are braces to ensure environment variables fare expanded properly. As in:
mint14@vb-mint14-64:~$ echo $EPICS_ROOT
/usr/local/epics
mint14@vb-mint14-64:~$ echo $(EPICS_ROOT)
EPICS_ROOT: command not found
mint14@vb-mint14-64:~$ echo ${EPICS_ROOT}
/usr/local/epics
I'll make these changes.
   Pete
On 3/17/2014 1:48 AM, Torsten Bögershausen wrote:
On 2/19/14 7:24 PM, Pete Jemian wrote:
I've just published a how_I_did_it for the Raspberry Pi
http://prjemian.github.io/epicspi/
Thanks for the pointer, I'm working on a script to do all
this automagically (tm), but it is not ready yet.
I post it here later.
However, some of the parentheses for the (~/.bash_aliases) are wrong:
#In shell language, $(/usr/local/epics/startup/EpicsHostArch) does the same
#as `/usr/local/epics/startup/EpicsHostArch`
export EPICS_ROOT=/usr/local/epics
export EPICS_BASE=$(EPICS_ROOT)/base
export EPICS_HOST_ARCH=`$(EPICS_BASE)/startup/EpicsHostArch`
export EPICS_BASE_BIN=$(EPICS_BASE)/bin/$(EPICS_HOST_ARCH)
export EPICS_BASE_LIB=$(EPICS_BASE)/lib/$(EPICS_HOST_ARCH)
export LD_LIBRARY_PATH=$(EPICS_BASE_LIB):
#Here we loose the old LD_LIBRARY_PATH, could the whole line could be
written as
export LD_LIBRARY_PATH=$EPICS_BASE_LIB:$LD_LIBRARY_PATH
export PATH=$(PATH):$(EPICS_BASE_BIN)
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
   Education is the one thing for which people
      are willing to pay yet not receive.
Re: Installing EPICS on the Raspberry Pi Pete Jemian
Prev: Re: Recommended practice for cvtRecord chain initialization Benjamin Franksen
Next: Re: Installing EPICS on the Raspberry Pi Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Installing EPICS on the Raspberry Pi Emmanuel Mayssat
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
