1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks VME Ctrl-X vs. Power Cycle
To: Matt Rippa <[email protected]>
Date: Fri, 21 Mar 2014 16:53:05 -0400
On Mar 21, 2014, at 3:21 PM, Matt Rippa <[email protected]> wrote:
> Can a modified reboot handler help with any of these occurrences?
With VxWorks, you can definitely get yourself into enough trouble that ^X or reboot() won't be enough. A SYSRESET or perhaps even a power cycle is needed. If you just have a terminal shell, you are out of luck. SNS built an option for sending a reset through the timing system to the timing receiver board which issues a SYSRESET on the backplane (although this is almost never used). Some VME crates have their own network interface which can be used to send a reset or power cycle. A network power cycler is another option. If you don't have something like that, and the crate is far away, you best option is careful coding.
Steven Hartman
[email protected]
Re: VxWorks VME Ctrl-X vs. Power Cycle Matt Rippa
Prev: Re: VxWorks VME Ctrl-X vs. Power Cycle Andrew Johnson
Next: Re: VxWorks VME Ctrl-X vs. Power Cycle Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: VxWorks VME Ctrl-X vs. Power Cycle Mark Rivers
Next: Re: VxWorks VME Ctrl-X vs. Power Cycle Matt Rippa
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
