1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Access to device connected RaspBerryPi SPI bus from IOC-Client
To: [email protected]
Cc: Christian Pauly <[email protected]>
Date: Wed, 26 Mar 2014 14:22:32 +0100
Dear Christian,
I have been working recently on a similar thing. I want to use the SPI
interface of the raspberry to set some threshold values using a DAC accesible
via SPI. I used the asyn driver code to do that. If you are interrested, I can
send you the code to be included in the ioc. It uses the wiringPi library to
access the devices on the raspberryPi. Currently I have only implemented
writing values, but the reading should be easy to be implemented.
I did not yet test it with real electronics (still in production), but I would
be willing to help you get the things working.
With kind regards,
Joern Wuestenfeld
Dr. Joern Wuestenfeld
Institut für Strahlenphysik
Helmholtz-Zentrum Dresden - Rossendorf e.V
Abt. FWKH           Tel: +49 351 260 3263
Postfach 510119     FAX: +49 351 260 3700
01314 Dresden       eMail: [email protected]
Bautzner Landstraße 400, 01328 Dresden
Vorstand: Prof. Dr. Roland Sauerbrey, Dr. Dr. h. c. Peter Joehnk
VR 1693 beim Amtsgericht Dresden
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Access to device connected RaspBerryPi SPI bus from IOC-Client Christian Pauly
Prev: Access to device connected RaspBerryPi SPI bus from IOC-Client Christian Pauly
Next: Dynamic Assignment is Sequencer Ganesh Jangir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Access to device connected RaspBerryPi SPI bus from IOC-Client Dirk Zimoch
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
