Hi Andrew,
I had done that to verify the install, and had built a custom
application, host-based, quite successfully. THe problem is with a
cross-build, and that fails in the top-level makefile with the error I
sent. I don't know why a cross-build of an application should need to
invoke a host-build (as indicated by the error message). THe top level
Makefile is the standard one:
#Makefile at top of application tree
TOP = .
include $(TOP)/configure/CONFIG
DIRS := $(DIRS) $(filter-out $(DIRS), configure)
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *App))
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *app))
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard iocBoot))
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard iocboot))
include $(TOP)/configure/RULES_TOP
so hence my belief there are config changes which cause my problem.
THanks,
Pete.
On 04/01/2014 10:31 AM, Andrew Johnson wrote:
Hi Peter,
On 04/01/2014 09:11 AM, D Peter Siddons wrote:
I am moving an application from 3.14.8 to 3.14.12. When I try to build
it I get immediately the following error:
make[1]: *** No rule to make target `install.linux-x86_64', needed by
`install.RTEMS-uC5272'. Stop.
THis is clearly a configuration error, but I can't put my finger on
where things changed between these two releases. Any suggestions?
Can you show us the Makefile that is failing? GnuMake's error messages
don't always help us know what the problems are.
I would suggest using makeBaseApp.pl to create an example app and
confirm that builds properly. Then compare the first few and last few
lines of your failing Makefile with the example's equivalent. Also look
at any differences between the files in the configure directories.
HTH,
- Andrew
D. Peter Siddons
Detector Development Group Leader
Bldg. 535B
Photon Sciences Directorate,
Brookhaven National Laboratory
Upton, NY 11973
email: [email protected]
Phone: (631) 344-2738
- Re: build question Andrew Johnson
- build question D Peter Siddons
<2014>
2025
2026
<2014>
2025
2026
