1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to open BEAST Prespective, during OPI runtime.
To: Ganesh Jangir <[email protected]>
Date: Thu, 3 Apr 2014 12:30:43 -0400
On Apr 2, 2014, at 12:15 PM, Ganesh Jangir <[email protected]> wrote:
> Dear All,
> How to open BEAST Perspective,Using widget, during CSS/OPI Runtime.
> I need to avoid to go CSS Development perspective to open BEAST,  during OPI Runtime.
Not sure what you mean by CSS Development perspective.
The typical workflow for setups that use the alarm system would be this:
In the control room, one instance of CSS is always running with the alarm display being open (alarm area panel, alarm table, annunicator. Maybe also alarm tree).
If an alarm happens, operators can see it, and typically also hear.
To handle the alarm, operators can then study the guidance of the alarm, open related displays etc. from the context menu of the alarm.
The workflow is thus alarm panel -> other displays, and not other displays -> alarm panel.
But if you really want to open a specific alarm view from a widget, you can do that via an Action Button which executes a script.
The Java code to open a view can be found in https://github.com/ControlSystemStudio/cs-studio/blob/master/applications/plugins/org.csstudio.apputil.ui/src/org/csstudio/apputil/ui/workbench/OpenViewAction.java, so you need to implement the relevant pieces in Javascript or Jython.
The view IDs for the alarm views are
        "org.csstudio.alarm.beast.ui.areapanel"
        "org.csstudio.alarm.beast.ui.alarmtree.View"
        "org.csstudio.alarm.beast.ui.alarmtable.view"
If you really want to switch to the alarm perspective, the perspective ID would be "org.csstudio.alarm.beast.ui.perspective", and example Java code for switching to a perspective, or resetting it in case it's already active but has been rearranged, would be in https://github.com/ControlSystemStudio/cs-studio/tree/master/core/plugins/org.csstudio.ui.util/src/org/csstudio/ui/util/perspective
Kay
How to open BEAST Prespective, during OPI runtime. Ganesh Jangir
Prev: Re: camonitor no refresh on .RBV field J. Lewis Muir
Next: CSS : Multiple IOC pv(s) disconnect on ethernet unplug Sud Roy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: How to open BEAST Prespective, during OPI runtime. Ganesh Jangir
Next: camonitor no refresh on .RBV field Chen Xue
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
