1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Modbus R2-6 available
To: "'[email protected]'" <[email protected]>
Date: Thu, 10 Apr 2014 14:28:49 +0000
Folks,
Release R2-6 of the EPICS "modbus" module is now available. This is from the release notes:
- Fixed a problem with function code 6 (write single register) on Wago devices when the MASK was not 0x0 or 0xFFFF.
  In this case a read/modify/write operation is required, and the driver was reading from the wrong address.
  On Wago devices the readback address for a register is offset by 0x200 from the write address.
  This offset was not being applied.
- Added 2 new records to statistics.template.
  $(P)$(R)HistTimeAxis is a waveform record that contains the X time axis for histogram plots,
  and MsPerBin is the time per histogram bin in msec.
The release notes are here:
http://cars.uchicago.edu/software/epics/modbusReleaseNotes.html
The documentation is here:
http://cars.uchicago.edu/software/epics/modbusDoc.html
The tar file is here:
http://cars.uchicago.edu/software/pub/modbusR2-6.tgz
Cheers,
Prev: RE: Streamdevice 2.6 autoconnection failure using drvAsynSerialPort Mark Rivers
Next: RE: Recommended practice for cvtRecord chain initialization Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EDM - where to find widget "Variable Scale Bar" Joachim Rahn
Next: Re: Sequencer build problem cygwin64 Benjamin Franksen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
