Just a quick follow-up. I have reproduced the problem, and indeed I found I cannot even stop a normal (not double-correlation) image with long exposure times without introducing problems.
I need access to a detector to debug this, and that will have to wait till after May 4.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Wednesday, April 09, 2014 6:24 AM
To: 周平; tech-talk
Subject: RE: How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module
Hi Zhou Ping,
I was not aware of this problem. I will test it today and see if I can reproduce it and find a solution.
From: [email protected] [[email protected]] on behalf of 周平 [[email protected]]
Sent: Wednesday, April 09, 2014 2:38 AM
To: tech-talk
Subject: How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module
Hi All,
The detector of our beamline is MarCCD and the type is SX165. It worked in areaDetectorR1-9-1 Module correctly. The parameters were as follows:
ADFrameType = DblCorrelation;
ADImageMode = Single;
marCCDStability = 0;
marCCDOverlap = Sequential;
In this condition, I found it can't stop acquire completely when it was acquiring. It can only stop front half acquire time and the back time can't stopped. For example, if I set the acquire time = 100s, then I clicked the start button to start acquire. If I want to stop acquire when it had acquired 20s for front half the nominal acquisition time, I clicked the stop button to stop it. And then I found it still acquired in the next half the nominal acquisition time which was 50s. It couldn't be stopped completely!
If I set ADFrameType to Normal, it could be stopped quickly. But the background noise was too large in this mode so I set ADFrameType to DblCorrelation for use.
Is there a way to solve this problem?
Thanks!
With best regards,
Zhou Ping
SAXS Beamline, SINAP, Chinese Academy of Sciences
Address:239 ZhangHeng Road,Pudong District,Shanghai,201203,P.R.China
Tel:86-21-33932019 Mobile: 86-18116357596
Email:[email protected]
- =?gb18030?b?UmU6UkU6IEhvdyB0byBzdG9wIGFjcXVpcmUgaW4g?==?gb18030?b?RGJsQ29ycmVsYXRpb24gTW9kZSBmb3IgTWFyQ0NE?==?gb18030?b?IGluQXJlYURldGVjdG9yCW1vZHVsZQ==?= =?gb18030?b?1tzGvQ==?=
- How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module =?gb18030?b?1tzGvQ==?=
- RE: How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module Mark Rivers
Re: Problem with UInt32Digital in Asyn Wilkins, Stuart
EPICS support plans for Solaris Andrew Johnson
<2014>
2025
2026
<2014>
2025
2026
