Can you make that record to be mbbo instead?
Usually, mbbi is for an enum coming from a device in the field.
Use mbbo to configure an enum from the user interface.
On 4/17/2014 11:26 AM, [email protected] wrote:
I am trying to toggle the value of an mbbi record in a BOY (embedded) action script.
The following simple code works for an ao record but not for an mbbi. The symptoms are that pv.setValue executes without error but does not change the value of the PV.
any ideas?
giles...
from org.csstudio.opibuilder.scriptUtil import PVUtil
from org.eclipse.jface.dialogs import MessageDialog
pv = widget.getPV()
val = PVUtil.getLong(pv)
MessageDialog.openInformation(None, "info", "pv value is %s" % val)
if val == 3:
pv.setValue(1)
elif val == 1:
pv.setValue(3)
else:
MessageDialog.openInformation(None, "Error", "no match")
Pete R. Jemian, Ph.D. <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source, Argonne National Laboratory
Argonne, IL 60439 630 - 252 - 3189
Education is the one thing for which people
are willing to pay yet not receive.
- CSS BOY Setting value of enum record in a python script giles.knap
MEDM: Passing PV Values to Shell Commands Poff, Mark A
<2014>
2025
2026
<2014>
2025
2026
