1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM: Passing PV Values to Shell Commands
To: "Poff, Mark A" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 18 Apr 2014 10:25:02 -0500
Hi Mark,
On 04/18/2014 09:23 AM, Poff, Mark A wrote:
> Is it possible to pass a PV value as the argument of a program call from
> a MEDM Shell Command button?  It seems like that would be a useful
> capability, but I can’t find any reference to it.  Somebody posted this
> question in Tech-Talk for EDM in 2004 (“EDM: Passing PV values to shell
> commands”) but it doesn’t appear that the question was ever addressed.
> Can anybody tell me whether this capability exists and if so, the syntax?
That's a great question. The answer is not directly, but you can have
the user select a PV from any widget on the display, and if you make the
shell command pass that through `caget -t` you can convert the name into
the PV's value before calling your program.
The Shell Command widget supports embedding the &P operator from the
Execute Menu command[1] which prompts the user to point to the PV to be
named before executing the command string.
Example: I create a Shell Command widget with a command set to
    echo `caget -t &P`
I also put at least one other PV on the screen. When I click the button,
the cursor changes to prompt me to click on a widget that will provide
the PV name. The caget command is then executed on that PV, and the
value returned gets echoed on the terminal where I started medm.
Of course if your PV name is fixed you don't have to use the &P part at
all, you can just name it directly in the caget call:
    echo `caget -t myPV`
Hope this helps,
- Andrew
[1]
http://www.aps.anl.gov/epics/EpicsDocumentation/ExtensionsManuals/MEDM/MEDM.html#ExecuteMenu
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
RE: MEDM: Passing PV Values to Shell Commands Poff, Mark A
Prev: MEDM: Passing PV Values to Shell Commands Poff, Mark A
Next: RE: MEDM: Passing PV Values to Shell Commands Poff, Mark A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
