1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Help about creat Archive Engine
To: <[email protected]>
Date: Tue, 22 Apr 2014 10:30:17 +0800
Dear
         I'm having trouble during the installation archive engine.
using the default plugin_customizationl.ini and preferences.ini
  Download the Eclipse for RCP and RAP Developers
                                     sns_css_src_3.2.16
                                     java version "1.7.0_25"
Java(TM) SE Runtime Environment (build 1.7.0_25-b17)
Java HotSpot(TM) 64-Bit Server VM (build 23.25-b01, mixed mode)
2014-04-22 10:21:23.237 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - PV prefix ca provided by JCA in org.csstudio.vtype.pv
2014-04-22 10:21:23.242 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - PV prefix loc provided by Local in org.csstudio.vtype.pv
2014-04-22 10:21:23.244 CONFIG [Thread 1] org.csstudio.vtype.pv.internal.Activator (start) - Default PV type ca
2014-04-22 10:21:23.247 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Archive Engine 3.3.0.201404171029
2014-04-22 10:21:23.424 INFO [Thread 1] org.csstudio.archive.engine.server.EngineServer (<init>) - Engine HTTP Server on http://localhost:4812/main
2014-04-22 10:21:23.425 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Reading configuration 'Demo'
2014-04-22 10:21:23.858 INFO [Thread 1] org.csstudio.archive.engine.model.ArchiveChannel (<init>) - No known last value for freddy
2014-04-22 10:21:23.859 INFO [Thread 1] org.csstudio.archive.engine.model.ArchiveChannel (<init>) - No known last value for sim://noiseWaveform(0,10,100,10)
2014-04-22 10:21:23.865 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Read configuration: 3 channels in 0.437 seconds
2014-04-22 10:21:23.865 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Running, CA addr list: 127.0.0.1
2014-04-22 10:21:23.868 INFO [Thread 28] org.csstudio.archive.engine.model.WriteThread (run) - WriteThread starts
2014-04-22 10:21:23.929 CONFIG [Thread 1] org.csstudio.vtype.pv.jca.JCAContext (<init>) - Using Pure Java CAJ
2014-04-22 10:21:24.239 SEVERE [Thread 1] org.csstudio.archive.engine.Application (start) - Unhandled Main Loop Error
java.lang.Exception: sim://noiseWaveform(0,10,100,10) has unknown PV type 'sim'
         at org.csstudio.vtype.pv.PVPool.createPV(PVPool.java:127)
         at org.csstudio.vtype.pv.PVPool.getPV(PVPool.java:109)
         at org.csstudio.archive.engine.model.ArchiveChannel.start(ArchiveChannel.java:200)
         at org.csstudio.archive.engine.model.ArchiveGroup.start(ArchiveGroup.java:136)
         at org.csstudio.archive.engine.model.EngineModel.start(EngineModel.java:297)
         at org.csstudio.archive.engine.Application.start(Application.java:193)
         at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
         at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
         at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
         at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
         at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
         at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
         at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
         at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
         at java.lang.reflect.Method.invoke(Method.java:606)
         at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
         at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
         at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Re: Help about creat Archive Engine Kasemir, Kay
Prev: RE: Warning messages in CSS Carcassi, Gabriele
Next: Re: Help about creat Archive Engine Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Sorry, Please ignore this new Email : Application Export from CSS IDE<EOM> Ganesh Jangir
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
