1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Point Grey Flea3 areaDetector ImageJ Viewer Problems
To: Zachary Brown <[email protected]>
Date: Fri, 2 May 2014 13:41:40 -0500
Perhaps EPICS_CA_MAX_ARRAY_BYTES is not set large enough ?
On Fri, May 2, 2014 at 1:00 PM, Zachary Brown <[email protected]> wrote:
From more testing:
A camonitor on PG1:image1:ArrayData shows that the values in the array are changing as the camera is moved around, so the array is getting updated.
ImageJ still shows a zero-value array.  The image shown from the plugin is 1280x1024 (8-bit) as it should be, but no pixel values.
The Array Counter in for the StdArray increases with the image count, but I did notice that the Unique ID for each array does not change (not sure if this is relevent, have not paid attention to this parameter before).
-Zachary Brown, John Dobbins
On Fri, May 2, 2014 at 1:02 PM, Zachary Brown <[email protected]> wrote:
Hello,
I am using the new Point Grey pre-built in windows 7 x64.  I am having issues streaming the images to the ImageJ areaDetector plugin.
I am able to acquire images in all image modes (single, multiple, continuous) and save the images using the TIFF plugin, but the NDStdArrays plugin does not seem to be getting any data, so the callbacks do not update, so the ImageJ plugin does not stream.
PG1:cam1:ArrayCallbacks is set to Enable
PG1:image1:EnableCallbacks is set to Enable
If any more information would be helpful, please contact me, thank you,
-ZB
--Matt Newville
Re: Point Grey Flea3 areaDetector ImageJ Viewer Problems Zachary Brown
Prev: Re: Point Grey Flea3 areaDetector ImageJ Viewer Problems Zachary Brown
Next: RE: Point Grey Flea3 areaDetector ImageJ Viewer Problems John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Point Grey Flea3 areaDetector ImageJ Viewer Problems Zachary Brown
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
