1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: about CSS BOY
To: "Kasemir, Kay" <[email protected]>
Cc: "<[email protected]>" <[email protected]>
Date: Fri, 16 May 2014 16:52:23 +0800 (GMT+08:00)
Thanks for your suggestion! Using try and catch, the problem is solved. Thank you!
在2014-05-13 20:30:46,岳敏<[email protected]>写道:
> CSS BOY handles the connections for you.
> By default, your script will only be called if all PVs are connected.
> If you do check the option "Execute anyway even if some PVs are disconnected", then yes, you'll have to handle the case that a PV is disconnected.
> You could do this:
> if pvs[0].isConnected():
>    value = PVUtil.getDouble(pvs[0])
> to check if the PV is connected, but
> 1) That uses the IPV#isConnected() call, and details of the PV implementation might change, so your script will not be portable.
>      OK, portability of scripts cannot be guaranteed anyway, but..
> 2) Race condition: The PV might be connected when you call isConnected(), but then disconnect just before you call getDouble, so you still get the error.
> So your best bet might be:
> try:
> except Exception, e:
>     # Well, something failed. Maybe the PV is disconnected?
>     pass
> -Kay
> On May 12, 2014, at 9:49 PM, 岳敏 <[email protected]<mailto:[email protected]>>
>  wrote:
>       I meet some problem while using CSS. The problem is when I use PVUtil.getDouble() to get the value of some PV, there will be ERROR in BOY console if the PV is disconnected. An example ERROR information is "2014-05-04 17:12:48 ERROR: Error exists in script/CSS/JavaScript/ECR_Print.js Wrapped java.lang.RuntimeException: PV SSC-LINAC:ECR:AGL-BEAM has no value. (script#23)". How can I check the connecting state in javascript code before I use PVUtil.getDouble()?
>  岳 敏 Min Yue
> Institute of Modern Physics, Chinese Academy of Sciences
> 509 Nanchang Road, Lanzhou, 730000, P.R.China
> Tel:+86-0931-4969469
> Handy: +86-18509316383
about CSS BOY 岳敏
Re: about CSS BOY Kasemir, Kay
Prev: 64-bit compatible CAEN SYx527 HV app Ru Igarashi
Next: no response first time, so I'm trying again Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: about CSS BOY Kasemir, Kay
Next: ssrlApps for devIocStats, etc Phillip Sorensen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
