1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Interest in an Ethernet version of the SIS3820?
Cc: Joanne Stubbs <[email protected]>, Peter Eng <[email protected]>
Date: Thu, 22 May 2014 19:08:51 +0000
Folks,
On a related note, Measurement Computing has just introduced a USB counter/timer card that may work well for low-end applications.  They had previously had a counter/timer model based on an old chip, and I had written EPICS scaler record device for it.
http://cars9.uchicago.edu/software/epics/measComp4303Doc.html
However, I think the CTS9513 chip became unavailable and they discontinued the device.
The new device can be found here:
http://www.mccdaq.com/usb-data-acquisition/USB-CTR08.aspx
It costs $429 for an 8-channel version.  Here are the specs:
High-speed pulse counter for general counting applications
8 counter I/O
48 MHz maximum input frequency
Programmable resolution up to 64-bits
Aggregate scan rate of 8 MB/s
Supports the following counter input modes:
- Totalize (event counting)
- Period measurements
- Pulse-width measurements
- Timing measurements
Debounce filter circuitry with flexible edge, level, direction, and debounce settings to better adapt to signals
Four independent pulse-width modulation (PWM) timers with count, period, delay, and pulse-width registers
Eight individually-configurable digital I/O channels
Synchronous high-speed reads of digital and counter inputs
External clock input and internal clock output
External digital trigger
No external power required
It is not clear to me yet what the 8 MB/s scan rate and synchronous reads mean.  I have ordered one and will see if it can be made to emulate a multi-channel scaler, i.e. arrays of digital counts as a function of time.  But even for a simple scaler/timer it could be useful with EPICS scaler record support.
Sent: Wednesday, May 14, 2014 6:37 PM
To: [email protected]
Subject: Interest in an Ethernet version of the SIS3820?
Folks,
Many sites are interesting in running EPICS data acquisition on non-VME systems.  For common laboratory and beamline control applications most of the devices we commonly use are available in non-VME platforms like Ethernet, USB, serial, etc.
However, one device which is used in many applications that is not really available in a non-VME platform is a high-speed counter/timer, particularly ones with buffer memory like the SIS3820.   If such a device were available in Ethernet, for example we could eliminate VME in our smaller EPICS laboratory installations.
I discussed the possibility of an Ethernet version of the SIS3820 with the SIS engineer today.  They have already produced an Ethernet version of one of their other modules, and would consider doing so for the SIS3820, assuming there was an initial order of at least 10 units.  It could probably be ready in 2015.
If anyone else would be interested in such a device could you please let me know, so I can gauge whether there would be enough demand for them to proceed?
Interest in an Ethernet version of the SIS3820? Mark Rivers
Prev: RE: how to know which PVs write to a PV Arnold, Ned D.
Next: Re: Re: how to know which PVs write to a PV LEI Ge
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Interest in an Ethernet version of the SIS3820? Mark Rivers
Next: 64-bit compatible CAEN SYx527 HV app Ru Igarashi
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
