1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: areaDetector acquirePeriod and acquireTime
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 6 Jun 2014 05:58:33 +0000
Hi Mark, all,
I've been thinking a bit about the relationship between the acquireTime and acquirePeriod parameters in areaDetector.
In some circumstances, scientists don't want any delay between frames, i.e. they want the acquirePeriod to be equal (or as close as possible) to the acquireTime.  They set this up for a given desired acquireTime, but are then sometimes caught out when they decrease the acquireTime but forget to decrease the acquirePeriod as well, so the overall frame rate is not what they expect.
I was wondering if people have a general way of dealing with this?  One possible solution would be to have an additional parameter to effectively disable the acquirePeriod, by forcing it to always be the minimum allowable value depending on the requirements of the particular detector and the current acquisition settings.  It would be nice to have a common solution across drivers/detectors if possible.
Cheers,
Emma
Re: areaDetector acquirePeriod and acquireTime Pearson, Matthew R.
Prev: Re: DC Power supplies with EPICS support Bruce Hill
Next: Re: areaDetector acquirePeriod and acquireTime Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Newport 8742 Picomotor Controller D'Ewart, J. Mitch
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
