1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: calc out record to verify pv not connected
To: "Goff, Steven J" <[email protected]>, "Mooney, Tim M." <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 10 Jun 2014 00:10:54 +0000
Hi Steven,
When I need to do this sort of thing I use an intermediate record that I know exists,
thus allowing the calcout record to process. If the remote PV does not exist, then
the intermediate will be invalid and I can test for that, i.e. something like:
record (ai, “MY_REMOTE_PV_ALIAS”)
     Field(SCAN, “Passive”)
     Field(INP,  “MY_REMOTE_PV CP”)
record (calcout, “REMOTETEST”)
     Field(SCAN, “1 second”)
     Field(INPA, “MY_REMOTE_PV_ALIAS”)
     Field(INPB, “MY_REMOTE_PV_ALIAS.SEVR”)
     Field(CALC, “B#3 ? ... : ... ”)
I set up the intermediate record to be ai, bi, mbbi, longin as appropriate, and usually set EGU, PREC etc as
appropriate as well in order to mimic the remote PV as best I can.
Regards
Andrew C. Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
From: [email protected] [mailto:[email protected]] On Behalf Of Goff, Steven J
Sent: Tuesday, 10 June 2014 7:52 AM
To: Mooney, Tim M.; [email protected]
We tried that and it did not work…
Sent: Monday, June 09, 2014 4:22 PM
To: Goff, Steven J; [email protected]
On my system, there is a delay of around 15-30 seconds after I unplug the remote IOC's network connection before INAV goes to 0, and a similar delay after I plug it back in before INAV goes to 1.  In my case, both IOCs are on the same subnet.
Tim Mooney
From: [email protected] [[email protected]] on behalf of Goff, Steven J [[email protected]]
Sent: Monday, June 09, 2014 2:46 PM
To: [email protected]
Subject: calc out record to verify pv not connected
I’m using a calcout record that uses a remote PV (from another IOC) as part of its calculation. I’m also using the INAV filed to test the link status of the remote PV. But I’m having problems getting it to work. While troubleshooting, I narrowed my calculation to be nothing more than to tell me what the connection status is. Here’ what I have:
Record(calcout, “REMOTETEST”)
                Field(INPA, “MY_REMOTE_PV”)
                Field(INPB, “REMOTETEST.INAV”)
                Field(CALC, “B”)
My understanding is that INAV returns an enumeration where 0 = not connected, 1 = connected, 2 = local PV and 3 = constant.
So when I start my IOC, REMOTETEST = 0 as expected. When I start my remote IOC, REMOTETEST = 1 as expected. When I terminate the remote IOC, REMOTETEST = 1. Shouldn’t it go back to 0? Especially since when I run “camonitor REMOTETEST.INAV” it toggles from 0 to 1 to 0 again. It looks like the “B” value never gets updated in the calculation once the remote connection is gone. Any ideas?
calc out record to verify pv not connected Goff, Steven J
RE: calc out record to verify pv not connected Mooney, Tim M.
RE: calc out record to verify pv not connected Goff, Steven J
Prev: RE: calc out record to verify pv not connected Goff, Steven J
Next: RE: areaDetector acquirePeriod and acquireTime Emma Shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Dependency issue with shared database templates unless using "make clean" Kasemir, Kay
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
