1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Compiling helloWorld of EPICS V4 on 64bit linux had a link error
To: 米清茹 <[email protected]>
Date: Thu, 12 Jun 2014 18:55:37 +0300
米清茹 <[email protected]> writes:
> Hi,
>     I compiled the EPICS-CPP-4.3.0 on 64bit centos6.5. As the
> HelloWorld in exampleCPP was compiled, an error occured. The error
> information shows below:
Editing a line in file helloWorldApp/Makefile could help.
Replace
        USR_SYS_LIBS += expat
with
	# USR_SYS_LIBS += expat
This should work since the code makes no reference to expat library. If
the code tried to do anything with expat library, there would be compile
time problems due to apparently missing expat.h header file.
> I can find libexpat.so.1 and libexpat.so.1.5.2 in /lib64.
> How to resolve the problem?
If you needed expat header files and files required for linking, you
would need to install expat-devel package (yum install expat-devel).
Jani Hakala
Compiling helloWorld of EPICS V4 on 64bit linux had a link error 米清茹
Prev: Re: Compiling helloWorld of EPICS V4 on 64bit linux had a link error Hinko Kocevar
Next: RE: EPICS database Feature request Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Compiling helloWorld of EPICS V4 on 64bit linux had a link error [SEC=UNOFFICIAL] LYNCH, Damien
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
