1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Parameter library in asynportdriver /areadetector
From: "Gomella, Andrew (NIH/NHLBI) [F]" <[email protected]>
Date: Mon, 16 Jun 2014 18:23:00 +0000
Yet another question regarding an areadetector driver I am writing (which is now mostly finished).
For some reason my parameter library is not getting set to the correct indices. In my writeInt32 function I put some printf statements and found out that my first parameter VarianMode is set to 3, but should be set to 78. (or vice versa?)
synStatus varian::writeInt32(asynUser *pasynUser, epicsInt32 value)
    int function = pasynUser->reason;
    //int status = asynSuccess;
    printf("VarianMode: %i", VarianMode);
    printf("writeint32 %i %i", function, value);
   if (function == 78){
        printf("function varian mode called");
        vip_select_mode(value); //varian function
(Explicitly just saying function ==78 was my quick fix to get things working as expected).
When I caput VarianMode 1
the first printf gives: VarianMode: 3
The second printf gives: writeint32 78 1
I've compared my code to many areadetector examples and can't figure out what I am doing wrong? Everything I'm doing seems exactly the same -
the declarations, the NUM PARAMS define (which is later used in the constructor)
#define NUM_VARIAN_PARAMS ((int)(&LAST_VARIAN_PARAM - &FIRST_VARIAN_PARAM + 1))
Any ideas?
Andrew
Imaging Physics Lab, NIH
Re: Parameter library in asynportdriver /areadetector Mark Rivers
Prev: motor module R6-8-1 released Ron Sluiter
Next: Re: Parameter library in asynportdriver /areadetector Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
